Question about Linksys Wireless-G WRT54G Router
Hey, i installed linksys wireless-g 2.4ghz wrt54g router but unable to secure, pls kindly help
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
You net to get into router settings options (try going to http://192.168.1.1) from internet explorer. and there you need to get to boradband settings and enable security (you will be asked to choose a password- key)
Posted on Jul 28, 2009
Testimonial: "Thanks, its now working"
  • Linksys Master
  • 2,263 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Posted on Mar 14, 2010
Can't find password
Reset the Linksys by pushing and holding the RESET button for 30 seconds or so, release, this will reset to default settings. Reconfigure SSID and Security. You may want to write down securith key for future use. This may help: http://homesupport.cisco.com/en-us/support/routers/WRT54G
Dec 29, 2012 | Linksys Wireless-G WRT54G Router
I need the Network security key to add my lapptop to the router.
http://www.pcwintech.com/screenshots-linksys-wrt54g-linksys-firmware
First, let's log on to the router.
  1. Open your internet browser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. In the login box that appears type 'admin' (without quotes) in both fields. 'admin' is the default username and password.
Write down the SSID
  1. In the Wireless > Basic Wireless Settings menu you will see the Service Set Identifier or SSID. The SSID differentiates one wireless network from another. It is the 'network name'. Write it down, or copy paste it to a text file. You will need it later. You can first set your own SSID if you like.
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
here you will find you wireless key. this can only be done by a machine connected directly by network wire. make sure you are connected first. wireless is unable to connect unless it is directly connected.
Sep 14, 2011 | Linksys Wireless-G WRT54G Router
Unable to set up secure wireless network
you can find the support for this router herre:
http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
the "guide me" section will run you through a few questions if you type in "wireless security" and give you basic instructions on how to setup a secure wireless connection.
Jan 02, 2011 | Linksys Wireless-G WRT54G Router
Linksys WRT54G Wireless Router Issue Allows 1 Computer at a time
Your router my not be DCHP enabled or it might not be assigning the IP addresses either.
I would do a reset and start all over with your security settings and see if that works. Worst case scenario you could always turn security off when your parents or others are there.
Link HERE for more Linksys information
pls rate 4 stars
Dec 01, 2009 | Linksys Wireless-G WRT54G Router
Linksys G WRT54G Wireless Router - Need to Secure
You can download your routers manual at this link.
I hope this helps.
Jan 16, 2009 | Linksys Wireless-G WRT54G Router
I bought a Linksys wireless G-WRT54G Router. When I purchases it I was told this was all I needed and how easy it was to set up. I have no idea what I am doing but I can not get it to work. I have a...
Other than the laptop and the LinkSys WRT54G, you would need an active account/subscription with an Internet Service Provider (ISP) who then will provide you with a modem of sort.
On initial setup, connect your modem to your laptop and verify that you can connect to the Internet. Thereafter run the CD installer that came with the LinkSys before connecting/powering the LinkSys. Follow on screen instruction. At one point in the installation, you would be asked to disconnect the modem, connect the router and connect the modem to the router.
Should for some reason the above instruction will not address your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Linksys Wireless-G WRT54G Router
Installing linksys wrt54g
The quickest/easiest is to boot your PC attached to the modem through an Ethernet cable without the WRT54G. Pop in the CD installer and allow the installer program to run. Closely follow on screen instructions. At some point you would be asked to reboot and connect the LinkSys using another Ethernet cable. Once rebooted, the program will auto configure the router and you should be be able to use it. Of course the PC must be set to "Auto Obtain IP Address".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Jun 27, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless-g wrt54g
Chances are yes depending on the version that you have. This model has been in production for some time and variations has necessitated different Versions (mostly on the firmware).
The LinkSys page for various downloads (including latest firmware) is here. Again, you need to specify what version is your WRT54G.
Apr 03, 2008 | Linksys Wireless-G WRT54G Router
Password request
Go here enter in your Version number that shows on under side of router
Download the newest software
What i am reading on web is indicating the software that came with that router will not accept the admin pw for some odd reason
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&packedargs=sku%3DWRT54G&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B01&displaypage=download
Nov 14, 2007 | Linksys Wireless-G WRT54G Router
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Nov 11, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
154 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
