Question about Vacuums
CLEANER SWITCHES ITSELF OFF AFTER A FEW MINUTES USE. IF LEFT FOR SOME TIME, IT WILL START AGAIN FINE, THEN AFTER A FEW MINUTES MORE USE , IT WILL SWITCH OFF AGAIN.
  • 97 Answers
Check all filters, if they can be washed do so, if not clean or replace. next check for a clog in the machine and in the hoses. the machine as a thermal device that if it senses an overload or getting to hot, the machine will shut itself off for safety resons.
Posted on Jul 29, 2009
Shark handheld vacuum shuts off after 10 to 20 minutes. What is the problem?
The motor probably has a heat sensor overload protector to protect the motor from burning out its motor windings. There is nothing wrong with the vacuum itself.
Apr 26, 2015 | Shark Handheld Vacuum Cleaner SV75SP
Bikegit
Replace the switch! It shut down when battery get depleted. and then when you start it again the cycle is shorter because the batery regenerate but not as previous cycle.
Jul 16, 2014 | Karcher WV50 Window Vacuum
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
The vacuum cleaner works for a few minutes then shuts off.After a few minutes it will start again,but soon shuts off again.
There may be as many as three air filters in the vacuum. Remove and thoroughly clean all of them and try again.
Gary
Apr 18, 2011 | Hoover Vacuums
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
Turning itself off
With newer models will not work things that you attach to the vacuum such as the hose and the carpet shampoo attachment. Loose attachments will work just fine. It is same diameter holes that are being used in later models.
Switch - there is not much you can do without getting inside of the vacuum. You have to access inside and get it fixed.
Rocky
Aug 22, 2008 | Kirby Heritage II Vacuum
Eureka the Boss bagless
Sounds like you have a clog somewhere. Check the filter inside the dust compartment, if is very dirty it won't allow ait to flow thru, Part #62132, DCF-H filter. Check the hose, take it off if you can and drop something in it to see if it comes out the other end, if it doesn't, then the hose is clogged. Check bown by the brush roll, the inlet may be plugged. Also if the belt is more then say 6 months old, you may want to replace it, I am sure it is strertched, part #61120B, extended life belt.
Jan 23, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuums Logo
108 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
