Question about Technics Audio Players & Recorders
Cd player keeps jumping when playing cd - Technics Audio Players & Recorders
  • 80 Answers
Try a CD/DVD cleaner disc. Try playing another CD after cleaning it. Do Not Wet the cleaning disc This will nock the lens out of focus
Posted on Jul 28, 2009
Cd player jumping
needs factory tune up.Sounds like laser output is weak when cold.
Oct 05, 2013 | Ford Focus Cars & Trucks
Cd keeps jumping and then stops playing. Fine on different player
how long have you been using this player? The problem should be from the lens (laser).
The lens is weak and that's why it cannot read/load Cd's. The weak lens is also what's making it jump.
Get a lens cleaner and use it to clean the lens, but if the lens still does the same thing even after using the lens cleaner, then it means you would have to change the whole lens completely to a brand new one.
By so doing your player would play all Cd's with no problem at all.
Good luck.
May 13, 2010 | Audio Players & Recorders
When playing a cd on AK27 it keps jumping
there are two things that might cause this,
  1. its either your speaker is too close to the system, whereby the bass come out from the speaker shakes the system and makes cd's to skip or jump
  2. or the lens (laser) of your player is weak. Also if the disc inserted into the player has a scratch, it will make the playing Cd jump/skip.
One of the above is the cause of the problem. So you can rectify the problem by observing from the above reasons.
Good luck.
Apr 16, 2010 | Panasonic SC-AK27 Shelf System
Panasonic SA-PM19 5 disc player jumps around, starting at or near first track, plays a little, then jumps a good chunk, plays a little more etc, until it reaches (quickly) the end of the disc. It does this...
Could be a CD defect, but probably just dust inside. Try canned air, or connect IPOD after you convert CD's to MP3's or other player to AUX port as a connector as a work a around. Splicers available online if you already have a TV connected.
Mar 20, 2010 | Panasonic Audio Players & Recorders
Used 200 cd player keeps skipping
I just fixed this using Scarthhouse's solution of removing the sensor assembly, cog, and squeezing the rack (of the rack and pinion) together (I squeezed the metal bar upwards). I'm not even electronically-inclined, so I'm ecstatic that this fixed the used 300 Sony disk player I just purchased.
Dec 30, 2009 | Sony CDP-CX250 CD Player
Hello please my cd player is jumping, when you play an audio cd it start skiping
If it only does it on some CD's see my Tip on removing scratches.
If it does it all CD's you need to clean the lens of the laser. If that doesn't work you might have to think about replacing the laser/lens. It might not be cheap either!
Dec 22, 2009 | Technics SCEH790 CD Shelf System
My tracks don't play in the recorded order, list I made them.....
If song tracks jump or skip then it is problem of cd player like optical laser is dirty / clogged,
and if track doesn't jump or restarts in middle of playing back then cd player is just fine,
Please check cd creator software settings.
Dec 18, 2008 | Sony CDX-MP40 CD Player
Teac pdh-300
Generally something that is time related with a CD player indicates that there is something stuck in one of the gear teeth that drive the laser back and forth to play different areas of the disc. A very small piece of dirt/sand can get inside and stuck in a gear tooth preventing the laser from moving past that point on the CD, in your case it's about the 40 minute mark........you can try skipping to say the last song on the CD which will advance the laser unit a bit more quickly than if you were to let the disc play through, that might dislodge the piece.
Another scenario could be a cracked gear in the same drive area. This is not as likely as you say it plays for 40 minutes or so. There is a piece that is attached to the laser which has gear teeth in it that mesh with the gears that move it, I'd suspect it's in there.
Make sure you do not have the player plugged in when you open it, the laser is capable of damaging your eyes.
Oct 07, 2008 | Teac PD-H300 CD Player
Hi i have a technics system but the cd player keeps jumping it seems like there is a scratch on the disc but they are new ! any ideas cheers leerobertsis@googlemail.com.
seems optical lens is dirty or have thin layer of dust on it.
open top cover of cd player and clean optical lens with good quality cotton swab with care and play again.
hope problem will resolve.
Sep 18, 2008 | Technics Audio Players & Recorders
When I play cd's the music jumps
Make sure the speakers aren't too close to the CD player. The sound waves could be causing it to jiggle around like Elvis singing Blue Suede Shoes.
Jan 09, 2008 | Audio Players & Recorders
261 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
