Question about Garden
The quick connect attachment on the hose is leaking when connected to the machine. I would like to take off that attachment and replace it with a standard connector similar to a garden hose. How do I do this.
3 Suggested Answers
  • 33 Answers
SOURCE: I purchased the karcher for
there should have been an adapter from the factory on it. if not you can go to the dealer and get one.
Posted on Apr 21, 2009
  • 1388 Answers
SOURCE: Had the Northstar 3000 psi Pressure Washer for 2
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
Posted on May 10, 2009
My 20 gallon campbell hausfeld wont hold air.what could be the problem
Joe:
There is an air leak somewhere in either the tank connections or the hose connections. Look at the tank and find the tube that runs from the top of the compressor to the tank (usually a brass line). grab a spray bottle and fill it with a soapy solution (dish washing soap and water is fine). Disconnect the rubber air hose from the tank (at the quick disconnect) and start the compressor. Spray the dishwashing solution on the brass line end fittings at the compressor head and the tank connection, and the quick disconnect fitting and where the quick disconnect connects to the air tank. If you see bubbles being blown, that is where your leak is. Also connect the hose to the tank and check your hose for leaks with the soapy solution. Once you find where the leak is, you can tighten the fitting or replace the faulty gasket or hose.
May 25, 2014 | Air Tools & Compressors
Fuel leak quick connector leak
Seeping like a connection at the quick disconnect is loose on one of the fittings? Or leaks alot like not connected all the way and a fuel injected Harley wont start? Or leaks alot like the quick connect fitting is broken internaly or has dirt in it?
Oct 11, 2013 | Harley Davidson Motorcycles
My washing machine is leaking water from the bottom right side when beening filled, I mean leaking all the water out. I had used it last and washed a small load with a pillow in the load. What could of...
first check the hose connections at the rear of the washer if no leaks than ur problem can be a few different ones their are hose connections and clamps connected to the motor/pump if ur lucky a clamp or hose is damaged-- unlucky problem seal leak or crack in unit
Sep 12, 2011 | Washing Machines
My washer is leaking from the bottom. I took the bottom panel off and found a black hose that is not attached to anything. When the washer is filling up the water is leaking out of this hose and all over...
if the hose is comming off the bottom of the tub, it will usually connect to the pump
if its the one afte the pump it may connect to the inside back wall, where your drain hose is
Oct 06, 2009 | GE Washing Machines
Water goes on to floor when filling washing machine. All hoses are connected securely.Machine was previously overloaded and shifted considerably when when nobody was home.
sounds like one of the hoses connecting drum or pump is adrift.most times these can be most readily seen with the machine lying on its back.make sure all power & water connections are off!
Aug 16, 2009 | Washing Machines
Whirlpool ultimate 2 model#lsw9750pw3 ser.ct1941128 leaking in front. appears to leak from a bow with 2 hose connected.
Your water pump is attached to the motor and is probably the source of your water leak.
Replace the pump.
Use the attached video to show how to access the cabinet and pump.
May 03, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
