Question about Tomtom GO 920 GPS Receiver
TomTom will not power on. Green light is lit.
Purcahsed in March 2008. Donloaded upgrade from TomTom and now the unit will not turn on. Since unit is now older than 1 year - TomTom does not fix them! Will I buy another TomTom? What do you think? I am holding $400 worth of trash! ANyone know of a person willing to work on TomTom's garbage? Here I come GARMIN!
  • 1 more comment
  • ekiernozek Jul 29, 2009
    I have tried the various "fix's" that TomTom Tech support has provided. Since I can not even get the unit to power up, I can not do a factory reset of the unit. My home computer is also no recognizing the unit when it is attached.
    There are instances when I get the TomTOm screen to come up and then it will go into the "remove card with he big red X" and in some cases it will roll up a screen with all of the parameters on the 920.
    Someone indicated that the unit may need a new battery. I may try it; however, the unit will not power up corretly in the craddle at the computer.
    All of my problems started when I downloaded the most recent "upgrade" from TomTom.
    Ed
  • ngadiscounts May 11, 2010
    First off, even though it won't power on push the reset for 20 seconds using a paperclip. It is located on the bottom of your TomTom. This is normal after a upgrade. If it still will not power on I buy broken TomTom's
    Have you tried resetting it? Use a paperclip and insert it in the hole on the bottom that says reset and gently push in the paperclip until you feel a click then hold it in for 20 seconds.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 171 Answers
Try holding the reset butoon for 30 seconds.
Posted on Nov 05, 2009
  • ngadiscounts Dec 01, 2009
    Try holding the power button down for 30 seconds.
Tomtom N14644 Canada 310 will not turn on. the green light is lit when plugged into a power source but nothing on the screeen
the green lit is let when plugged into power source.The tom tom is not turning on..Please help
Aug 01, 2011 | GPS
Green lite will not on . when unit is pluged in
press reset+power for 20 seconds, then release reset ank keep pressing power, it will turn on for 10-20 secs, in this time you must connect it to the pc. run tomtom home and make the upgrades that the program sais. must help.
Apr 20, 2011 | Tomtom One XL GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
MY TOM TOM WILL NOT TURN ON. THE GREEN LIGHT IS ON, AND IT'S CHARGED.
try to press and hold the power button for 10 seconds then release and check if you can replace the battery or if the unit is still under warranty try to call their support if they can replace the unit if the unit is still under warranty.
Jun 09, 2009 | Tomtom GO 700 GPS Receiver
Doesn' t turn on
1. Connect the TomTom to the USB for power (green light should be on).
2. Hit the reset button on the bottom of the device - you should feel it depress slightly.
3. Press firmly and hold the power button and count to 10.
5. Try this a couple of times if it doesn't work the first time.
Even if your battery is ****, the power connection has a pass-through, so you can still use the device as long as its connected to the charger.
Dec 19, 2008 | Tomtom GO 720 GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Cant reset tom tom
I have now resolved my Tomtom 1 V2 problem (posted 12th Nov 2008).
I emailed Tom tom directly, describing the problem I was having, they responded almost immediately.
Tomtom could not have been any more helpful, the advice they gave me was spot on, and absolutely correct.
Not only did they solve the error I had with my unit, but they made it work much better than it ever had.
Briefly, I was told to join (for free) Tomtom Home, then delete all of the operating system on my satnav and download the latest Tomtom operating system, plus a few other upgraded programs.
I am no computer genius, and admit to being more than a little apprehensive in doing this, but, it could not have been a more straight forward or simple procedure.
As before, my Tomtom now works so much better, faster and with far more features.
Another benefit of being a member of Tomtom Home is that you are offered many products such as map updates at greatly reduced prices.
Regards,
Chris Vince
Sep 17, 2008 | Tomtom ONE 3rd Edition GPS
CANNOT RECHARGE TOMTOM
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Feb 16, 2008 | Tomtom One Europe v2 GPS Receiver
Will not power up
Had same problem with my GO910 unit, after it was about 6 months old. Contacted TomTom and sent unit back. They said that they are aware of the problem. They sent me back a new GO 720 with 2008 maps as they said they could not fix the problem in the 910. and they were not importing anymore 910 into Australia.
Dec 26, 2007 | Tomtom GO 910
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Tomtom GO 920 GPS Receiver Logo
247 people viewed this question
Top Tomtom GPS Experts
k24674
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
