Question about Garden
I have a McCulloch model number FHH18A/FHH20C. The brass fitting that comes out of the pump has broken. It's brass and plastic. McCulloch claims there is no replacement part, except to purchase a new pump and motor. Is there any after-market check valves that would replace this fitting/valve?
  • 5 Answers
SOURCE: brass part in wand handle because the brass fitting
Bronze breaks, why it does not have flexibility. it substitutes part for steel inox
Posted on Jun 05, 2009
  • 174 Answers
SOURCE: I just bought a replacement pump today. Model
The oil will be in the stainless steel or silver colored part of the pump. If there is no access to this part then the oil is put in there by the manufacturer. I believe the small red plastic plug you speak of covers the overheat blow off valve. Just leave it. When you run the washer for a long time you may see some water spill out of there. The only way to change the oil is to separate the two pump sections. Not advisable without some knowledge and the correct tools
Posted on Aug 12, 2009
  • 19 Answers
SOURCE: Where can I purchase oil rings that go into the
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Posted on Sep 14, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I need a manual for a McCulloch pressure washer
Your manual can be downloaded from here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2006/MOUS2006_7096H18A01.pdf
If the above link does not work start here: http://www.mccullochpower.com
Which should get you to this page where you type in FHH18A as the model number
http://www.mccullochpower.com/node7877.aspx (Use for ANY McClloch
Course of last resort.... Call them at this number: 1-800-521-8559
Thanks for choosing FixYa,
Kelly
Posted on Oct 18, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I have a Annovi Reverberi
I may have left this up too long but.... what is the make and model of the pressure washer. if this is an AR pump there is not an inlet screen as part of the pump. It is part of the plumbing between the water supply and the pump inlet. Disconnect the hose connection pull out the hose washer and look for a plastic screen behind the hose washer. If you see nothing... disconnect all the plumbing that connects to the pump and test for flow while it is removed. If you have flow then there is something blocking the pump water supply inlet. If could be parts from the unloader valve. Pull out the unloader valve and inspect the hole. Make sure to lubricate the unloader valve with grease before re-installing the unloader valve.
I really need the pressure washer model number to point you to the parts your asking about.
Kelly
Posted on Jun 03, 2011
Parts
You should refer to your owners/service manual for the correct part numbers.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 04, 2014 | McCulloch FHH18A Electric Pressure Washer
Mccullough FHH18A - Looking for connector adapter/ size ?
Why not just purchase a new hose assembly?
Contact us
User manuals
McCulloch Service
Jul 03, 2014 | McCulloch FHH18A Electric Pressure Washer
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
I have a mcculloch washer # fhh18a / fhh20c. pump will not turn on all of sudden.
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Sep 13, 2011 | McCulloch Garden
My washer does not spray the cleaner solution as high as it did originally. The high pressure spray is fine.
If your pressure washer works like ours, it has a T connection.
A plastic hose comes off the T and goes into the bucket of cleaner
Pressure from the hose creates suction across the T and this draws cleaner into pressure hose
The plastic hose from cleaner connects to a small brass ball valve on the T
The ball valve clogs up or changes over time and cleaner will not draw up into the pressure hose.
We would replace the valve stem
I don't know if they sell the little replacement parts like they used to
Finally we had so much trouble.
We started applying our chemical with a pump-up sprayer.
For us, it was cheaper, and the work went faster.
We put one guy on the pump up sprayer
And then another guy came behind him on the washer.
Oct 25, 2010 | McCulloch FHH18A Electric Pressure Washer
I can't find the directions and need to know how to get the cleaning solution to come out of the machine.
You can download your manual here:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FHH20C-7096H18A03-966990001.pdf
Instructions for chemical tank 1 and 2 use are on page 6. Wand must be in the low pressure position to dispense chemicals.
Thanks for using FixYa.
Kelly
Kelly
May 10, 2010 | McCulloch FHH18A Electric Pressure Washer
Pump burned out?
Contact us
User manuals
McCulloch Service
Sep 24, 2009 | McCulloch FHH18A Electric Pressure Washer
Where can I purchase oil rings that go into the spray wand of a McCulloch FHH18A electric power washer.
Sep 10, 2009 | McCulloch FHH18A Electric Pressure Washer
I need a manual for a McCulloch pressure washer FHH18A. Download did not work.
I need a manual for McCulloh 1600 PSI pressure washer > Its motor is working but there is no pressure
Aug 23, 2009 | McCulloch Garden
Brass part in wand handle because the brass fitting
Jun 05, 2009 | McCulloch FH180A Electric Pressure Washer
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
