Question about SanDisk Sansa m240 MP3 Player
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
  • 1,511 Answers
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Posted on Jul 28, 2009
Why can´t I change information. eaven format do not work.
When I understand this problem for the m250 right:
you can switch on the player but the text in the display cannot be changed pushing buttons.
Manual for the m200 series: http://mp3support.sandisk.com/downloads/um/sansa-m200-um.pdf
First check the LOCK switch; it should be disengaged when wanting to use the player's buttons.
If that won't help, try to RESET the device, see next link for 2 solutions:
http://kb.sandisk.com/app/answers/detail/a_id/1115
When the m250 still won't respond, do the FORMAT as told on this page:
Hope this will restore your player.
When needing more help, just add your text in this answer.
May 30, 2010 | SanDisk Sansa m250 MP3 Player
Sandisk sansa m250 mp3 player problem
try formatting it or updating the firmware
Feb 11, 2010 | SanDisk Sansa m250 MP3 Player
Not enough space for Music DB, please free 8 MB
The Sansa m250 requires a separate folder to load your songs to in order to achieve the full 2 GB. Set your USB to MSC. Plug it into your computer. Create a folder TUNES. Then drag and drop your mp3 or wma files to this new folder.
Jan 28, 2008 | SanDisk Sansa m250 MP3 Player
"Not Enough Space for music DB Please free 8 MB"
What type of formatting did you do? I suggest that you could try to hard reset by
  1. Turning off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 24, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
Not enough space to listen
If it''s any consolation, the same thing happened to me after I loaded about 1.6 GB (~250 MB left) of music on my Sansa m250. I tried to delete the required 8MB, but the directory structure got destroyed to the point where my computer wouldn''t recognize the device. I called their technical support and they''re having me send it back to them for a replacement! It''s not you, but the player! I don''t know if there''s anything that can be done from a consumer standpoint.
Jul 09, 2007 | SanDisk Sansa m250 MP3 Player
MTP DB Mismatch format?
i have the same problem...but i have a deferent model....and what is a scan disk
Jun 12, 2007 | SanDisk Sansa m240 MP3 Player
My sansa m250 says "not enough space for Music DB Please Free 8MB".. when...
I received the same problem, I thought I had done a Sync by mistake and had used of all the space. I had to re-format the player and start over.
Jan 27, 2007 | SanDisk Sansa m250 MP3 Player
Error message: Not enough space for music DB. Please free 4MB.
Hi I have just bought a Sandisk Sansa M250, we loaded som music on it and it lasted 2 hours, then it the message came "Not enough space for music DB please free 8 MB". I couldnt even go in to the menu. I contakted Sandisk.com and 24 hours after they came up with an answer. If it's currently frozen, hold down the power button for 20 seconds in order to soft reset it. Let's try to format the player (THIS WILL ERASE ALL FILES FROM THE PLAYER). Plug it into your computer, then open My Computer, right-click the drive associated with the player, and choose Format. It may give you a choice of file system, if so, choose FAT (it may only let you choose FAT32, which is fine). Now click on Start and it should format the player. If not already done, please also update the firmware from this link: http://www.sandisk.com/Retail/Default.aspx?CatID=1368 The 20 seconds on the power button didnt work, but the formation did. Hope this helps. //Cadmann Please bear with my english
Aug 20, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
136 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
