Question about LG Flatron L1512S 15" LCD Monitor
Burn In When the screen is turned on it says "Burn In" then it starts flashing different colours. Ive left it for about an hour once but it just kept going. Not sure whats going on with it.
0 characters
1 Points
My Acer P196hqv moniter is always offset by about 50mm when I start my computer, and I have to use the moniter controls to correct it. Very frustrating!
this is because the boot up screen and the welcome screen comprises of many differences they differ in resolution ,colour depth etc so if once the moniter is set for welcome screen it may be irregular for boot window
Mar 24, 2011 | Acer 22" X223w LCD Monitor
I have a monitor, i actualy don't know the name of the model, but i have the model number.. ive had this problem for around 3months and can't find a way to fix it. basically, it's that old story about...
The input (either VGA/HDMI/DVI) maybe be defective. Generally with these sorts of problems, either something goes defective in the port, or the cable. You said you tried different cables, so, it is probably the connection to the port inside of the monitor. Hope this helps!
Feb 28, 2011 | RCA IISonic IIMJ9 19 inch LCD Monitor
My whole screen has a blueish green tint
  • Make sure the plugs are hard into the sockets, one loose pin can cause strange colour problems.
  • A faulty signal cable between PC and monitor can also cause colour problems, try a different cable if possible
  • Try it on a different computer to find out whether the computer or the monitor is the problem. If it's the monitor and none of the above works, it will need service or replacement. If it's the computer, your video card is likely to be the problem.
Apr 09, 2010 | Samsung Syncmaster 940BW LCD Monitor
My hannspree monitor recently started flashing colors
i have 3 hannspree monitors 2 were sent back for repair i replacement was faulty when i got it back the other one changes flashing colours never again i tried turning the brightness to full which helped for a time
Mar 29, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Dell monitor flashing different colours and buttons won't work!
Go into your monitors settings and select "Factory Reset" Then go to "Factory" and you will find the burn in setting. Turn burn in to off. This should fix the problem.
Jan 08, 2009 | Dell E176FP 17" LCD Monitor
LG1717S - Power light flashing - no image.
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 03, 2008 | LG L1717S-BN 17" LCD Monitor
Benq monitor flashes primary colours when switch on or off
This is called burn-in mode. Used to test the monitor at the factory.
To fix this, use the buttons under the front of the monitor,
There are six buttons. Let's number them 1 to 6 from the left.
Press 6 to display menu (at the bottom in Red will say Burn in mode on)
Press 4 or 5 until Recall is highlighted
Press 6 to select
Press 4 or 5 until Recall All is highlighted
Press 6 to select
Press 4 or 5 until Yes is highlighted
Press 6 to select
Press 3 to exit
This will reset all paramaters and also turn-off burn-in mode
If you want to reset some parameters to your preferences, press 6 again to bring up menu and
see you user guide to get explanations for the different settings.
Dec 10, 2007 | BenQ FP71E 17" LCD Monitor
Blank Screen Now.
Backlight is torched, it happens without warning. These can be repaired, but finding the appropriate backlights, and trying to get this thing apart is a royal pain in the you know what! But your backlight has burned out! Sorry!
Sep 30, 2007 | BenQ FP731 17" LCD Monitor
Mag Innovision LT776s 17 in. Flat Panel LCD
I have the same problem except it usually happens after Ive left my computer idle for a while... i.e . Overnight, I usually turn off the monitor and I hit the button after I come back to turn it on. I get the same flashing light for several minutes. This has been a problem for several months, but only recenly have i gotten the same error message you mentioned. Each time ive booted the computer up cold or restarted it has worked fine but this time it took longer along with displaying the message: Top Left to Right: SH770 P001 Bottom Left to Right: AU M170EN05 Anyone else who can clear this up?
Mar 04, 2007 | Mag Innovision LT776s 17" LCD Monitor
Two vertical lines across screen
This is a common problem when LCDs are subjected to strong shock. Your internal circuits are damaged The panel itself may not be cracked but there is internal damage. I know of no cure or repair possible other than to replace the panel assembly.
Sep 24, 2006 | Samsung Syncmaster 730B 17" Flat Panel LCD...
LG Flatron L1512S 15" LCD Monitor Logo
49 people viewed this question
Top LG Computer Monitors Experts
Lawrence Oravetz
Level 1 Expert
Are you a LG Computer Monitor Expert? Answer questions, earn points and help others
