Question about Epson Stylus Photo R2400 InkJet Printer
Client-error-not-possible message New printer showing the following error: client-error-not-possible Using Mac OSX10.5.6, had to down load the driver from the Epson site. Any help would be appreciated
jackboy
  • 2985 Answers
SOURCE: epson R220 on a mac
I would think that indicated certain faciliies are not available on a mach. Check out the full manual- On the CD. Surf the model in www.fixyourownprinter.com Check a Mac forum.
Posted on Sep 24, 2007
SOURCE: Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Posted on Nov 10, 2007
totoman
  • 48 Answers
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Posted on Sep 05, 2008
SOURCE: We cant install our new Epson printer FX-2175 for it has no installion CD -Driver
Here you go, the drivers are in this link:
http://www.epson.com.ph/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=2&pid=819
Posted on Sep 25, 2008
  • 55 Answers
SOURCE: the epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Posted on Feb 09, 2009
60.20 error
The tray 2 lifter-motor is not functioning
Unfortunatly this usually requiers parts
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness is full seated in its connector on the dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver assembly
-If the unit is still clicking/banging with a new lifter replace the tray -If the unit is still clicking/banging with a new lifter and tray see step 5 5 Replace the dc controller PCA.
Apr 22, 2014 | HP LaserJet 4350dtn Printer
Trying to add cannon mp450 printer to my mac and error 9672 shows up it will not print
Click OK on the message prompt to close the message.
Uninstall the Epson Printer software that came with your printer using the uninstaller. Follow the on-screen prompts to uninstall the product.
From the hard drive, click Applications, then click Utilities and select the Printer Setup utility.
Click Add.
If your printer shows up in the printer list, select Printer. If the printer does not show up in the list, choose either Bonjour or Rendezvous as the connection type and then select the printer from the list.
Under the Print Using list, select epson stylus CX5000.
In the list of available drivers, select the epson stylus CX5000 - Gimp-Print driver.
Click Add
Using the Gimp-print driver might provide basic print-only functionality. This driver is a built-in driver in the Macintosh Operating System and will not provide all of the features that are provided using a direct USB connection.
Jan 03, 2013 | Canon Pixma MP450 All-In-One InkJet...
Epson CX9400Fax Error Message
Sounds like a software issue. Reinstall or call Epson tech support.
May 18, 2009 | Epson Stylus CX9400 Photo Printer
Cannot print using my HP C4150 all-in-one
go to start then to control pannel then go to printers and put your printer'sname in the box
Jan 17, 2009 | HP Photosmart C4150 All-In-One InkJet...
When installing the 6310 all in one printer, at a certain point I get the following message: "The application HPIO Trap Monitor quit unexpectedly. Mac OSX and other applications are not affected. Click...
There are two ways for install the Scanner using only "the driver" and using "HP Photosmart Studio Includes Support for Mac OS X v10.3, v10.4 and v10.5 (Leopard)" using the driver not include IRIS OCR software only the driver to scan and thats why say "An OCR error ocurred, couldn't create file". Installing the HP Photosmart Studio fix the problem.
If fixed the problem visit my page www.richardsite.com.mx
Jan 16, 2009 | HP Officejet 6310 All-In-One InkJet...
MacBook Error 36
Error 36 means “I/O error” (input/output error) and does not explain what the cause of the problem is, sorry.
Check your Mac for bad blocks you can use Disk Utility.
Aug 11, 2008 | Apple MacBook Mac Notebook
Unable to print documents from microsoft word (MAC) using my new hp 1005 printer. message appearing "client error- not possible"
Try printing the test page from the computer to check if printer has been installed properly or not.
If not then try reinstalling the printer.
Aug 07, 2008 | HP Office Equipment & Supplies
Printer doesnt print on leopard in mac
Check out this blog for the answer to your Brother 2140 and MAC printing problem.
http://iamdotnetcrazy.blogspot.com/2010/07/client-error-not-possible-brother-hl.html
May 02, 2008 | Brother HL-2040 Laser Printer
Epson Stylus Photo R2400 InkJet Printer Logo
591 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
