Question about Poulan Garden
I have a poulan 3700 20'' chainsaw, and the isolator #530024225 has broken. I have the new part, but i have no idea how to install it. can you help?? thanks...gerry Z
dennisgladx
  • 52 Answers
SOURCE: Poulan Wildthing 18" chainsaw 2375 sprocket/drum replacement
mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 mso 9]> mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi tchild,
my name is Dennis Gladx and I can assist you with the problem of getting the sprocket off of the crankshaft of your chainsaw.
To remove the centrifugal clutch and sprocket you unscrew it from the crankshaft and it has a left hand thread. Also a little trick to remove anything from a crankshaft that could turn while you want to unscrew the item, Remove the spark plug and insert some rope into the cylinder for the piston to squeeze against and you will jam the piston without damage.
Glad to be of assistance Please rate this solution because I can learn from your rating. Thank you
Posted on Nov 08, 2008
  • 211 Answers
SOURCE: HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Posted on Dec 02, 2008
steve_lima
  • 181 Answers
SOURCE: compression Poulan chainsaw
you can not set the compression on two cycle motors,the compression new is at about 90 to 95 pounds after six to nine pulls of the recoil
Posted on Jan 07, 2009
SOURCE: Poulan Pro 42 chainsaw will not start
I had the same problem on a P3416 saw. I had a new Champion plug and coil installed. I tested the plug by removing it and plugging it in the coil wire and ground the end of the plug on the engine block. It did not spark so I bought another plug. This one fired but it was real weak so I loosen the coil and slipped a piece of light folder paper between the coil and magnets and tighten the bolts. Got a better spark and got it to run.
Posted on Mar 05, 2009
dontbother10
  • 2220 Answers
SOURCE: lost my manual for my poulan pro 255 chainsaw the
If looking for parts your OM is of little value. You can find an IPL (exploded parts list) here (only one PP255 listed):
http://www.ordertree.com/modelinfo/PWE/PP255-Gas-Saw/75.PP255-Gas-Saw.1.59.1.html
Rear vibration (isolation spring)s appear to be item 5 or 59 on the "Exterior Assembly" print.
Poulan replacement OM.
http://72.3.225.179/manuals/87722e.pdf
There is contact us number in the OM if you want to contact Poulan. HTH
Lou
Posted on Feb 15, 2010
Testimonial: "thank you very much for the information that you sent me. i spent two hours on a dial up modem trying to find the part and 20 seconds to read your rep"
Why my choke want stay out on poulan chain saw
Detent broken? Lever stop broken?
New ones are here
The word is ' won't ' by the way :>)
Poulan Pro Chainsaw Parts
Jul 09, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do i replace fuel lines?
Where do the fuel and primer lines go in Craftsman or Poulan Chainsaw
Hope this helps. Also try to avoid using gasoline with ethanol. This causes the lines to deteriate.
Apr 30, 2016 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
One more try before I trash it. I have a poulan p3314 chainsaw. It is 2 years old. Installed new carb,fuel lines,air filter, and spark plug. Fuel is routed properly. Can't get unit to fire. Any ideas.
Check the gap between the magneto and the magnet on the flywheel, if it is too much of a gap you wont get spark. We are talking .007 inches or less. You need a feeler gauge to set this
Apr 22, 2016 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Poulan chainsaw will kick back when trying to start it. It has a new cylinder and piston kit just put in it.
Sounds like the timing is too far advanced.
I'd be pulling the flywheel and retard the spark about 2 degrees.
Jan 18, 2016 | Poulan Garden
Poulan chainsaw not getting any spark???
you might have a broken wire to the spark plug. Use a meter to check continuity on the wire.
Aug 08, 2014 | Poulan 16" 38cc Gas Chain Saw P3816
Replacing engine assembley isolator
Most brands of saws require partial disassembly of the saw to replace the isolators. Yours is probably no excepion. You should take numerous pics on your smart phone during disassembly to eliminate a lot of questions during reassembly. Make sure the correct length screws go back in their respective holes if there are multiple length.
Some older saws required near total disassembly to do it correctly.
Jul 06, 2014 | Poulan Garden
Lost my manual for my poulan pro 255 chainsaw the model number seems to be missing on the machine. i have a balance spring underneath thats broken near the rear of the chainsaw. need a part number for the...
Lou
Feb 14, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
42 cc engine
I didn't see a complete engine assembly at Poulan. Ask them.
Handheld (Chainsaws, Trimmers, Blowers, Edgers)
1 (800) 554-6723 or
http://www.poulanpro.com/node4033.aspx
A new cylinder and piston are about $75.00, plus shipping, if available here:
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
An inquiry for repair at a local saw shop might be worth an inquiry.
An entire new saw PP4218 is $150.00 @ Walmart.
Did you borrow someone else's saw and run it on straight gas? HTH
Lou
Oct 08, 2009 | Poulan Garden
Chainsaw pull cord wont tension up
Its almost certainly made by Poulan.
This may help you find an IPL at Sears, they are available:
http://www.searspartsdirect.com/partsdirect/modelHelp.pd?modelNumberId=29
This lists all Poulans. It will be difficult to find your saw but it is here:
Poulan.com
It sounds as though the starter spring is broken.
This thread explains how to reinstall the spring.
http://www.fixya.com/support/t1839024-broken_recoil_spring
The IPL for your saw shows all the parts and provides an idea of how they fit together. GL
Lou
Sep 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
43 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
