Question about HP DesignJet 110 Plus InkJet Printer
HP 110 plus shows problem with black printer head
Occurred after installation of new black ink cartridge. Small 300k print job from AutoCad on computer starts to send to printer and sends only 65K of 300 k file. Printer prints about 1/2 inch on one side of paper then spits paper at me. Then flashing black printer head on printer. If I turn of the machine and restart the flashing bad printer head sign goes off. I have a computer hammer, but don't own a printer hammer. Help!
  • 724 Answers
Glad you mentioned Autocad has a printer/plotter setup setup
Posted on Jul 28, 2009
Hi, I desperately need immediate help about how I can refill HP deskjet 1050 cartridges printer. Just refilled using syringe needle but the printer won't print and the cartridges ink level is showing...
Your printer will be using either of the foll:
HP 802 Black Ink Cartridge CH563ZZ
HP 802 Small Black Ink Cartridge CH561ZZ
HP 802 Small Tri-color Ink Cartridge CH562ZZ
HP 802 Tri-color Ink Cartridge CH564ZZ
after refill, use a dry tissue paper to wipe the head....(small metal head with 2 lines for ink flow in the bottom of the cartridge)...u also need to clean the small metal dots(15 to 20) on the cartridges...(these dots are for data....trf... connecting the cartridges to the printer....)
keep cleaning till the ink flow is fast and your tissue has lot of ink marks....hold the tissue in one hand (pam) and press the head to the tissue....move the cartridge on the tissue in a manner from say top to bottom of your pam....do this 5 to 6 times till the ink starts to flow smooth....
if the above does not give you the desired result....of clean ink flow....
the other option is to immerse the cartridge head (only) in hot boilling water.....
to do this....
boil water in a bowl....remove bowl from gas stove / microwave....pour the hot water in another bowl(normal temp...it will help you hold the bowl with your hand...just the water will be hot ) and immerse the cartridge head portion in it for some mins...till you can see the ink come out....wait...... and use the above tissue clean process for some time.....re-do the process if you dont see the ink flow...in the tissue....once you note lot of ink in the tissue....wipe the cartridge dry and install in printer and do a test print.....
you can also reset the ink level....give me some tiem and i will let you knwo how do that...
once you can print.....let me know....i will tell you the reset trick....
Reg
Kris
May 07, 2011 | Office Equipment & Supplies
My HP Model B209a Photosmart Plus all in one printer has quit printing black ink. New cartridge installed but still no black ink is printing.
on the head assembly, you will see some copper pins contacts, try to clean them with cotton swabs dab in alcohol..same with the print cartridge contacts..
Feb 09, 2011 | Office Equipment & Supplies
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
The black ink cannot be
Are you confident the new cartridge is full and in-date? Can you confirm that the old cartridge was not removed until immediately before the new cartridge was installed? Did you remove the yellow tape from the new cartridge before you installed it? Was the black cartridge change properly completed such that an ink charging cycle occurred? Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If not, do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then there are other things we can try - assuming other solutions haven't worked either. Report back on my queries etc.
Feb 10, 2009 | Epson Stylus C43SX InkJet Printer
New Cartridge - Black showing no ink
u check ur head is working properly i think this main error of head where u insert balck vartrige if u have same printer then u have check replace the black cartrige find out it work properly then sure ur balck head is damage
Nov 04, 2008 | HP Business Inkjet 1000 - Printer - colour...
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Aug 07, 2008 | HP OfficeJet D135 All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP DesignJet 110 Plus InkJet Printer Logo
540 people viewed this question
Seeker5211
Seeker5211
