Unfortunately, I don't have a hard-copy of the manual. However, you can find the manual here: https://support.garmin.com/support/manuals/manuals.htm?partNo=010-01681-02&language=en&country=US . If you take the PDF file on a USB drive to any print shop, you should be able to get a bound hard copy for a fee. The direct link to the PDF of the English version manual is http://static.garmin.com/pumac/DriveSmart_51_61_OM_EN.pdf .
I hope this helps.
SOURCE: Not enough space for maps?
The garmin does not have any space on it for maps,any additional maps are stored on a memory
card. I don't see where garmin says the size limit of the card but in most cases unless it says
SDHC memory card,then the max is a 2g sd card, I think the models 500 and over can use over a 2g card.,
SOURCE: Nuvi 205w won't read upgraded map
You HAVE to go through software support as this is an issue with the map. They told me it is because the map KEY is wrong, it is only for the united states, but the map is ALL of north america. The wait time is incredibly long, I have been waiting for over an hour, such bad service
I just got off the phone with tech support. They have a very
complicated fix that involves remote accessing into your computer and
editing files, etc. They said it would take over an hour and a half, I declined.
The problem apparently is that the nuvi 200/205 can't support canada, but
the maps contain canada = problem. and btw, i downloaded "City
Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the
same problem. this filename ends in a "B", apparently that's the
"fixed one" but acc tech support it's only fixed in the sense that they
can waste over an hr w' u fixing it, whereas the older files are
unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
SOURCE: Have a Garmin nuvi 200 with North America maps.
It will depend on how much memory you have in your Garmin. If you have maps that you want to keep then I would download those first and then add in the Ireland maps. Or wait until you leave to add in Ireland. I believe the Garmin will tell you if there isn't enough room to add in Ireland.
Testimonial: "Thanks again Gemmy23"
SOURCE: Are there free City Navigator North America map
The numaps guarantee ensures you can get free map updates if there any available only for the first 60 days of use, after that all updates do need to be purchased
