SOURCE: i have a broken ink cartridge holder on a lexmark 730 series.it is saying ink cartridge missing
Hi David,
Unless you have a very expensive printer or you know of a store that has a wide range of used printers, it won't be worth your time and money to order a new cartridge tray for your printer.
I would suggest buying a new 730 series printer and keeping the old one for spares.
If however you're curious as to the price of a new cartridge holder it would be your best bet to browse to www.lexmark.com and do a parts enquiry from the website.
Best wishes,
Graemevm
You may try to clean the rollers using a slightly damped paper towel.
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
