SG Twelve Posted on Sep 20, 2017
Hp photosmart C7280 blocked on flags HP after resetting
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on May 08, 2009
SOURCE: I cannot print C5 envelopes on HP C7280
In page setup manage custom paper sizes. Enter the size of the envelope and save it. In print dialogue box you can find the C5 envelop. Paper size: defined by driver. This should work
Anonymous
  • 71 Answers
  • Posted on Jun 20, 2009
SOURCE: HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Anonymous
  • 54 Answers
  • Posted on Sep 12, 2009
SOURCE: HP PHOTOSMART C7280 ERROR 0xc18a0001
Follow the steps carefully from the front panel of the All-in-One.
1. Get the unit into the “Support Menu” by following the steps given below.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Now Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Now the Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11.Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Anonymous
  • 30 Answers
  • Posted on Jul 26, 2010
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Anonymous
  • 214 Answers
  • Posted on Nov 04, 2010
SOURCE: HP photosmart C7280 ink system failure 0xc05d0281
Go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&rule=11380&product=1153494&key=null
AirPlay HP Photosmart C7280
Yes you can.
I share a supported link please visit and read guide. I hope solved your issues.
http://support.apple.com/kb/ht4356
Thanks,
HP Printer Support
Photosmart c7280 ink threshold exceeded
Sad to say I know how to fix this.
1. Power up the printer
2. set printer's date to the current day.
3. On the keypad press the * and # keys together
Now press one at a time 1,2,3 for the code
"screen stould display a white backround with 2 lines of info"
4. remove all the print cartridges
5. Press the >> arrow button twice until "reset menu" is found
6. Press OK
7. Select Partially full reset Press ok
( the printer will take almost to minutes before it powers down)
8. Power up the printer and follow the steps.
reinstall ink ect......
I don't know why this happens but I sure a lot of printers are in the trash because of this. If you print out a SELF TEST REPORT the
dates on the age of the ink Cartridges are likely out of life range.
Planned obsolescence by HP can be found all over the web. This could be one of those.
HP Photosmart 3000 C6100 C7200 PSC 7280 Printers HP 02 Cartridge...
Press the helpfull Thanks!!!!
2answers
How do i get my hp photosmart c7280 back online i have a print job but says printer is offline - but it is connected
remove and insert the cable in another usb port.if the problem continues change the usb cable and try
2answers
My HP photosmart c7280 not sending or recieving faxes.
try reinstalling the drivers. make sure your telephone line is plugged in correctly and is functional
How to scan, what icon to click
Visit to the given link and download the manual or user guide. The complete procedure for scanning is mentioned therein...
http://www.retrevo.com/support/HP-C7280-Multifunction-Printers-manual/id/3837dj879/t/2/
http://www.generalmanual.com/Printers/HP-Photosmart-C7280-All-in-One-Printer.htm
Hope this has helped you... Please rate the answer... Thanks...
1helpful
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
2helpful
Will not print
dirver conflict, completely remove from OS, take off network and see if HP works independently well. reset on network and share again.
k24674
Grand Canyon Tech
Grand Canyon Tech
