Question about Car Audio & Video
1996 Ford Explorer Radiator Removal
I can't seem to figure out how to seperate the engine radiator from the air conditining radiator. They are connected by what appears to be a sleeve on the top, right hand side, (facing the engine from the front). There must be a simple way. I'm replacing the water pump and the fan clutch and am going to send the radiator to a shop to be flushed. Please help.
Thank you.
  • kenm007 Jul 24, 2008
    I am looking for the tabs that disconnect the raditor from the condenser in my 5 letter V8 explorer.
You don't need to knock out the tabs.
The problem is that the condenser connector is fit through the holding bracket and that locks the two pieces together.
First, remove the bolts holding the shield in place and push it out of the way. Take out the two bolts on each side. The lower one on the RHS (drivers side) is into the lower tab. There is a tab on the lower left that pops out and allows the LHS to separate. Then, move the radiator as far to the right as possible. On the bottom right, there is a small tab that fits into the radiator tank ridges. pry that out and push it to the front of the car. Now, take a long punch, rod or screwdriver and drive the upper tab out toward the center of the radiator. Do the same with the middle tab. This separates the radiator from the AC condenser.
You can put it back together like it was, but I cut about an inch out of the front side of that bracket so that the AC connector can be pushed through it. I had to take it out a second time and was very happy about that modification.
This is a poor design and the slot cut really helps.
Posted on Jul 01, 2008
Both solutions really helped. However, the tabs are so tight, I'm afraid of breaking them but I guess its the only way. This is rediculous. Anything to make the dealership and mechanics more oney. They wanted $600 to replace what I should be able to do for $180 at the max. Thanks so much. It took me a very long time to find this site.
Posted on Oct 04, 2008
I replaced the radiator in my '97 Explorer and had to break the mounting tabs on the driver's side to separate the two parts. Ford installs both parts as one unit to cut production costs and passes the pain along to the repairman. If you're reinstalling the same radiator then I don't know how to do that without breaking it.
Posted on Dec 02, 2007
02 ford explorer 4.0 overheating and suddenly blowing cold air, then hot again while engine runs cool but not long
Most likely you have air trapped in your engine, particularly in the heater loop. You need to properly bleed the air out of your radiator cooling system. The hot and cold blasts of air coming from first hot water followed by air.
Read up on how to bleed air out of your radiator system. Some systems are very difficult to bleed.
If after doing a good bleed of the radiator system the problem returns, you may have a bad head gasket or other leak in your cooling system which is injecting air into the cooling system (radiator/water cooling system).
Aug 12, 2014 | 2002 Ford Explorer
My 1996 ford explorer was running fine today. I came home and parked and then returned to find a puddle of coolant. I filled the radiator with water and the reserve with water. I ran the engine for...
make sure the engine is fully warmed up (check the temp gauge and feel the top hose from the radiator to the engine) that hose should be HOT and it you should NOT be able to calopse it-it should feel hard. If you do not have a leak under these conditions, you probably just have an overfull surge tank and it 'puked' out some fluid. If you top radiator hose is NOT hard after the engine is fully warmed up, you have something wrong-it could be as simple as a radiator cap that is not sealing properly, or a leaky hose, an intake manifold leak, or an internal leak in the engine (don't rule out a leaking radiator, it has end tanks that can and do leak).
Sep 05, 2011 | 1996 Ford Explorer
I have a '96 Explorer that has started overheating. I checked the fluids, which were low and refilled them. It continued to get hot and when the fluids were checked again they were empty-same day. I...
Are you just refilling the coolant resevoir, or also adding antifreeze/water mix to the radiator itself?
When the engine is cool, remove the radiator cap and add antifreeze/water mix until the radiator is full. Leave the radiator cap off and leave the hood up and start the engine and let it idle. As the engine warms up the thermostat should open up around 180 degrees and allow the water to circulate in the radiator. If you see no movement of the water and the heat continues to rise to an unsafe temperature, your thermostat is stuck and needs replacement
May 16, 2011 | 1996 Ford Explorer
How do you change the thermastat on the 2005 ford explorer sport trac
  1. 1 Drain the coolant from your Explorer into an adequate container by opening the drain plug at the bottom of the radiator. Save the coolant for reuse if it is relatively new and clean.
  2. 2 Remove the negative battery cable from the battery if your Explorer has a 2.9-, 3.0-, 4.0- or 5.0-liter engine. This step is not necessary for 2.3- and 2.5-liter engines.
  3. 3 Follow the upper radiator hose to the front driver's side of the intake manifold, where it meets the engine. This is where the thermostat housing on your Ford Explorer is located. If necessary, remove the air cleaner duct for easy access to the housing.
  4. 4 Loosen the clip on the end of the radiator hose and pull the hose off the thermostat housing. Use a 10mm wrench or socket to remove the two retaining bolts on the thermostat housing cover. Remove the cover.
  5. 5 Note the position of the thermostat before removal. Pull out the old thermostat. Seat the new thermostat inside the housing in the same position as the old one, spring-side facing into the engine. Install new gasket over the thermostat.
  6. 6 Reattach the thermostat housing cover and the radiator hose. Reinstall the air cleaner duct if removed earlier. Fill the radiator with reserve or new coolant. Start your Explorer and run with the heater blowing until the engine gets warm. Check for leaks.
Read more: How to Change the Thermostat in a Ford Explorer '
Jan 28, 2011 | 2005 Ford Explorer Sport Trac
I have replaced my radiator three times within the past 2 years on my 1996 Ford explorer. Each time the heater is turned on the radiators develop cracks. I had the last radiator changed together with the...
you may need to check/raise the quality of the parts you are buying. You dont say what engine you have? if the radiator cap is incorrect or bad, it may have too much pressure on the cooling system.
Dec 21, 2010 | 1996 Ford Explorer
My vehicle blows cold air all the time i have replaced the heater core the radiator and the thermostat still no warm air
if you replaced the core then there is no way the temperature blender flap is stuck open? it is possible that you have a big air bubble in the core and there is nothing circulating in it? it does sit higher than the engine, if so burp it out. did you happen to video the core removal/install process and put it on youtube?
Nov 25, 2010 | 1996 Ford Explorer
I have a 1996 ford explorer and my heater when I first get in and it slightly warmed up the heat works great then as i drive a little the temp gauge goes way up 2 hot then back down to normal and the...
You probably have air in the system. Take off the radiator cap and start the engine. Turn the heater on hot. Let it warm up and fill the radiator as the level drops. Make sure the thermostat opens and coolant is flowing in the radiator. Continue to add coolant until the level stops dropping. Also check for any bleed ports on the hoses or housings where they attach. If you see any bleed ports, crack them open and let any air out. Put the cap back on and see if the heater is working. If this doesn't work, please get back to me.
Nov 03, 2010 | 1996 Ford Explorer
HAve a 1996 Ford explorer v-8 that is overheating,
With cool engine... open radiator cap and look inside radiator. Do you see lots of sediment and calcium growth on radiater tubes? If yes, a coring may be needed. If only slightly bad, a radiator flush may be needed... then refill with 50 percent antifreeze.
Good thermostat, cleaned cooling system, non-leaking water pump, good water flow via water pump... nothing else left (unless you put the thermostate in backwards)..
Let us know
Oct 24, 2009 | 1996 Ford Explorer
Water heating radiator and water expulsion oily reddish color
Sounds like you have transmission fluid in the antifreeze. The transmission cooler might be leaking in the radiator. If it is, replace the radiator.
Mar 26, 2009 | 1996 Ford Explorer
Car Audio & Video Logo
756 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
