Question about Garden
Sluggish when started, light smoke
When the lawnmower is started it runs rough and light smoke comes out. After awhile it starts cutting off, it will start again after several pulls but then cuts off again and then starts the cycle all over again, can you help?
  • 87 Answers
Check carb an get a can o sea foam
Posted on Jul 28, 2009
What causes my 1994 lexus gs300 to start smoking an running rough an cuts off. white fuel smoke.
'white smoke' is in fact steam which leads me to think your head gasket has gone which would explain the running rough. Is your coolant going down? You can hire a pressure tester for the coolant system.
White smoke is steam
Blue Smoke is oil
Black smoke is rich mixture, too much fuel
Aug 02, 2017 | Lexus Cars & Trucks
Occasionally runs rough
This is usually caused by a bad crankshaft postion sensor.
Oct 02, 2008 | 1991 Mazda 626
Runs smooth then runs rough & rough back to smooth running.
If your check engine light comes on get it checked. To me it sounds like an engine misfire probably cause by a coil pack or spark plug wire going bad. The misfire should cause the check engine light to come on maybe even flash if the misfire is bad enough
Aug 19, 2015 | 1996 Chevrolet Cavalier
Smoking and hesitation when i start it up
check the coolant level. if it is low or empty you have a blown head gasket. On acceleration the leak in the head gasket is causing the rough running and stalling
Oct 12, 2013 | 1996 Honda Accord
Ryobi rcs4040ca chainsaw
Its unusual for a saw to start actually smoking, are you sure the chainbrake has not come on and you have been running it, this will make it smoke and damage the clutch, sprocket and brake.Remove the side cover and check for signs of heat,
Aug 31, 2013 | Garden
94 trailblazer runs really rough for awhile after sitting ,after running awhile its starts to run fine (worse on cold days) help please!!!
Have a pressure bleed down test run on the fuel pump, that is the most common problem that causes this condition.
Aug 23, 2012 | Cars & Trucks
1991 Honda 750 Nighthawk...been running great. Hadn't ridden it much last 30 days or so...got on it tonight, noticed a sluggish throttle. Initially, there was slight black smoke coming from the exhaust....
carb. needs to be rebuilt sounds like trash in the float body or in the needles try using some sea foam in the gas tank (if u get it to start again) it has probably fouled out the plugs
Nov 02, 2009 | 1992 Honda CB 750 Nighthawk
Lawnmower cuts out on fast idle + runs rough
REBUIld carb it is dirty jet is clogged
May 25, 2009 | Echo Garden
Garden Logo
248 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
