SOURCE: W850G Wireless Router Forgotten Password
The default is admin(ID) and motorola(password). There is a reset button on the back and it can be reset via software. See http://broadband.motorola.com/consumers/products/WR850g/downloads/WR850G_userguide.pdf
Reset will reset everything.
SOURCE: i have forgotten the user name and password. can
Open Hyperterminal and get the Username: prompt. Press the reset button once, wait 1 second, push reset button again, wait for the login prompt and then use apc and apc as username and password.
SOURCE: MacBook Air: ive forgotten login name & password...
Follow these steps to reset a password when there is only one
administrator account on the computer, or if the original administrator
account needs a password reset.
Reset MAC original administrator account password
SOURCE: I have forgotten my password
Generally all routers have a little button on the back of them where the ethernet ports are that you have to push with a pen for 5seconds that will reset your router to it's factory default settings, this includes any user names and passwords used for an internet connection or any wireless security settings
this will also reset the username and password for logging into the router
SOURCE: user name and password are
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
