Question about Dell F3534 Touchpad
Touchpad icon does not show up in sys tray anymore. cannot find touchpad in hardware
I want to disable my touch pad on a dell d620, but the icon is missing from my system tray ever since upgrading to office 2007. Can anybody help?
Posted on Jul 29, 2009
  • 724 Answers
Blue funtion
on a Micron it is the f3 key and in blue this toggles them back and forth
The funtion may be different on your dell
look for a square slash dot... hirogliphic design
Posted on Jul 28, 2009
  • tommya300
    tommya300 Jul 28, 2009
    Blue funtion
    look for a square slash dot... hirogliphic design made for the
Asus touchpad no longer scrolls / works
do you have an icon in your sys tray? You should be able to right click on that and check the properies.
Not go to
Start -> Type "mouse" (without quotes) and click on the mouse link
This will open your mouse and scroll. Check your settings.
Finally, have you installed anything lately. Sometimes when you install new software or a new device it will conflict with the old drivers and you have to work around this to get them both functioning again
Mar 28, 2013 | Computers & Internet
My safe to remove icon has dissappeared how can re install it please
Which operating system ?????????
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon?
http://www.pulpfusion1.com/demotech/e_article000253202.cfm
Mar 13, 2013 | Compaq Computers & Internet
Touchpad quit working for tapping
check for your trackpad settings mainly in the system tray icon on the bottom right corner and then right click the trackpad icon and make sure that tap to click is enabled.
if the icon is not there in your icon tray then look for it in the control panel and enable the tap to click option...
hope this helps
Jul 13, 2012 | Gateway Computers & Internet
My aspire D255E netbook is only about 2 months old, the mouse pointer moves, but i am not able to select anything using the touchpad or the touchpad buttons. I was wondering if there was a solution for...
Check if the drivers for the touchpad is installed. Usually you can find an icon at the system tray for your touchpad. Check device manager if there is a problem under mouse and other pointing devices. You can also try double clicking the device under that category and try to roll back the driver if possible. If it still does not work, try running a hardware diagnostics on the touchpad. It could be a hardware problem.
May 12, 2011 | Computers & Internet
I'm using toshiba satellite a305. originally the touchpad is working fine, surely. but yesterday, out of the blue i am still able to use it to scroll but it does not recognize single tap or double tap....
Vertically and horizontally finger scrolling on my vaio laptopnw series is not working any more or maybe i have deactivated it,i had a touch pad icon on my toolbar hiden icons before ,but not anymore.how...
Hi sheki_68,
If you have disabled the Scrolling Feature of the Touchpad, you will need to re-enable for the function to work correctly. You can enable the Touchpad Setting from the Control Panel, Mouse Options.
  1. Click the Start button and then click Control Panel .
  2. In the Control Panel window, click Hardware and Sound .
  3. In the Hardware and Sound window, click Mouse .
  4. In the Mouse Properties window, click the Function tab.
  5. To enable the Scroll function, click to check the box next to Use Scroll Function.
  6. Click the OK button and then close the Hardware and Sound window.
This should re-enable the Scrolling Feature of the Touchpad. If the Function is not available in the Mouse Properties window, you may need to re-install the Touchpad Driver in the Computer to fix it.
Good Luck!
Hope this helps.
Please post back if you require further assistance.
Thanks for using FixYa.
Oct 20, 2010 | Sony VAIO NW270FS Series 155" Notebook PC
Can't see the touchpad icon on the system tray
Hi! I have a Dell Inspiron 1520 laptop with a touchpad (this model is a bit older than yours). If you want to see the touchpad icon in the System Tray so that you can change the settings and so forth, here is how to do it in Windows XP:
1. Go to Start, then Control Panel, then Mouse.
2. In the Mouse Properties dialog box that pops up, look for a tab called "Dell Touchpad" and click on it to select it.
3. Click on the big picture of the touchpad with the arrow in the middle of the new dialog box that pops up.
4. You should now see a new window that says "Dell Touchpad" pop up.
5. At the bottom of the Dell Touchpad window, click the checkbox that says "Display icon in taskbar" (you should see a checkmark in this box).
6. You should now be able to see the Dell Touchpad icon in your System Tray.
7. If you still do not see the Dell Touchpad icon, or if you do not see a tab that says "Dell Touchpad," then try re-installing the driver for the Dell Touchpad by going to:
http://support.dell.com
Enter the service tag of your laptop, or its model number (Inspiron 1525), then hit the Confirm button. You should see a new window pop up that shows all the compatible drivers for your laptop. The one you will need in this case is under the section "Input Device Drivers." Look for the driver for the Dell Touchpad, download it, and then install it, if necessary.
Also, please make sure that you can see all the icons in your System Tray. If you can't, then try clicking on the little left-facing arrow in the System Tray, which will expand the System Tray to show all the icons there, and then you should be able to see the missing Dell Touchpad Icon.
I do hope this solves your problem. Please feel free to comment on my solution, and rate me as to how I did. Thank you!
Feb 21, 2010 | Dell Inspiron 1525 Notebook
I want to deactivate my touch pad on my dell inspiron 1525 laptop. Please advise how
If you do not see a Touchpad icon in your systray(lower right), go to:
Start/Control Panel/System
On the left choose "Device Manager".
Select "Mice and other pointing devices" and highlight "Dell Touchpad"
Either right click and "Uninstall" or click the uninstall icon at the top.
Restart your machine and it will automatically update the driver from Dell which will put the Touchpad icon back in the system tray.
Click on this icon and go to "Device Select"
Check the "Disable Touchpad/Pointing stick when external USB mouse id present.
Sep 24, 2009 | Dell F3534 Touchpad
Sansa mp3 player
If the player is in MTP/Autodetect you can just unplug the player from the computer. You can check this by going to the My Computer window and see if the player is listed and if it has a drive letter before it, if it dont have a drive letter then it means the player is in MTP/Autodetect you can just unplug the player from the computer.
Aug 13, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
775 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
