Could not date your Marlin. These links should help though -
Marlin Model 60 22 Caliber
https://www.thefiringline.com/forums/showthread.php?t=221883
SOURCE: Marlin model 70P, serial #14388170 date of manufacture
1986
Take the 1st two numbers of the serial number, and subtract from 100.
14388170 = 14
100 - 14 = 86 = 1986
Testimonial: "sounds about right considering the condition of the rifle. Thanks"
SOURCE: I'm trying to see what year my marlin lever action rifle is.
1883
Found here:
http://oldguns.net/sn_php/marlinlookup.php
SOURCE: What year was marlin model 55. Serial number
1979
On Marlins made from 1948 and later, subtract the 1st two digits of the serial number from 2000.
Serial number 21615408
1st two digits = 21
2000-21 = 1979
SOURCE: When was a Marlin model 60, serial number 15457098 manufactured?
Go to marlinfirearms.com . Click on Customer Support, and pose your question. There is nothing like going to the source.
SOURCE: How to determine the model and serial number of a marlin 22 rifle?
this is copied from a site, the web address is pasted below.
The serial number depending on the model of rifle, will be located either on the upper or lower stock tang, or side of the receiver.
http://www.gunvaluesboard.com/marlin-serial-numbers-dates-of-manufacture-1664.html
also if you find serial # you may find more info here.
From 1962 thru 1968 Marlins rimfire rifles (other than the 39 series lever actions) used a two letter date code that was stamped on the barrel. This date code is different than the one already listed, as Marlin rimfire rifles (other than the model 39 series) did not have a serial numbers until required to by Law after 1968. The first letter of the date code represented the month of manufacture while the second letter indicated the year. This date code was usually stamped on the left side of the barrel just in front of the receiver.
