My dimplex wall fan heater fx20 switch broke and i
My dimplex wall fan heater fx20 pull cord switch broke and i am looking for a replacement at present i cannot turn the internal switch on or off
  • 86 Answers
Www.torreelectrics.co.uk/acatalog/Dimplex_wall_fan_heaters_FX20.html try this site
Posted on Jul 28, 2009
I have a small wall heater, towel rack included, the fan & timer work, but no heat. Where do we find the model number
Usually on a small sticker on the back near where the wire goes into it.
If you know the make you can Google it and look at the images tab like this for 'Dimplex bathroom fan heater'.
dimplex bathroom fan heaters Google Search
Jan 22, 2016 | Heating & Cooling
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Dimplex Fx20ve 2kw Timer Wall Mounted Bathroom Downflow Fan Heater Pull Cord is stuck
turn of the powere and take the cover off and clean the pull cord and the use a bit of lubricant to keep it free that should loosen it
Sep 24, 2013 | Dimplex Fx20ve 2kw Timer Wall Mounted...
Plug the new fan motor, nothing
Sounds as if the Fan Switch may also be faulty. Or the new fan motor is defective. Is the flame function on the electric fireplace working? If the flame function is working, than obviously the fault is either in the fan switch or the new fan motor.
If the motor has a regular receptacle type plug on the end of the cord, try plugging it directly to a wall outlet and see if it works. If you're able to do that, then the problem is in the fireplace's fan switch or in the wiring circuitry going to the fan motor. Perhaps, this is what was wrong all along and not the fan motor, itself.
If nothing is working, check the wall receptacle that the fireplace is plugged into, by plugging in an electric lamp. If the lamp won't turn on, then there's a circuit breaker tripped in your homes circuit breaker panel. Check the circuit breaker panel for a tripped breaker and with nothing plugged into the offending receptacle, reset the breaker. Plug the fireplace back into the receptacle, turn it on and see if it trips the circuit breaker. If it does, there's an electrical short some where in the fireplace. Look for burned or frayed wiring, as well as bad connections.
Hope this helps solve your problem.
Feb 15, 2011 | Dimplex DF3003 Electric MidSize Heater
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
Nov 16, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
Dimplex epx1000 switches off after approxomately 10 secs
This looks to be a nice quiet unit! a thermal overload is likely the culprit,
amp draw may be too high, take amp draw to see. stat can be also bad.
Nov 01, 2010 | Dimplex DXLWP400 Electric Wall Mounted...
How to install a wall dimplex thermostat to a dimplex fan wall heater /RDH2010tcw/1000/2000W/240
disconnect wire A from the thermostat, and connect it directly to one of the supply wires. Connect B and C to the other for 2000W.
Mar 03, 2010 | Heating & Cooling
Fire place insert light replacementht
Dimplex has discontinued use of the remotecontrol unit you have requested; therefore we are no longer able to providethis as a replacement part. In order to operate your unit please plugyour power cord directly into your wall outlet and operate the stove via themanual switches.
Aug 20, 2009 | Dimplex Compact Electric Flame Stove...
Dimplex DS5804 remote unit
Call Dimplex : 1-800-668-6663 ext# 358 They will be gla to help and send parts if needed.
Dec 09, 2008 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
435 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
