Question about Cycling
I have a problem with my spring loaded seat - is this a do-it-yourself repair?
    Problem Solver:
  • 10 Answers
And the problem is?
Posted on Jul 31, 2009
1998 explorer passenger side seat lever / diagram
Find a seat at a junk yard. No one sells those parts. Dealers will only sell you a new seat. You spend 3 hours pull the covers and parts off the seat only to find out, You can't fix it.
Aug 30, 2015 | 1998 Ford Explorer
Agitator might be going out.
You have a damaged bearing and seal. I strongly recommend a trained technician to repair. You can really mess things up by doing it yourself. It takes a seal puller and bearing setter plus all the other tools. If you try it yourself and gouge the bearing seat or seal seat you are doomed!
Apr 05, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Can I Fix Spring Loaded Mechanism on the Brica Roll n Go Car Seat Transporter?
Contact Brica directly at:
BRICA Inc 500 West 5th Street Suite 220 Charlotte, NC 28202
USA 866.869.8257 (toll-free in USA)
www.brica.com
Nov 24, 2013 | Brica Roll n Go Car Seat Transporter
Mx-5 belt won't pull out
the seat belt has a spring and can become twisted and not completely go back in on its self you need to pull the seat belt all the way out, and slowly let it back in it should reseat its self make sure there is no twist overs while it goes back in.
Jul 15, 2017 | Mazda MX5 Cars & Trucks
My driver side seat sits low and I descovered it was due to a loss of springs after I checked under both seats and saw several springs were holding the pass seat but only one was holding drivers seat...
Instead of attempting to rebuild your seat, have you considered finding one in a scrapyard? Seats are not too terribly expensive, you could even do an up-grade and you would save yourself a ton of annoyance. Since it's not a mechanical problem that could be dangerous, you can do this at your leisure and not be forced into buying something you don't like.
Sep 19, 2010 | Dodge Dakota Cars & Trucks
Seat removal 2006 hd flstc got screws loose-but just spring load
If ths is a 1 piece seat ; are all 3 screws loose? If so you may need to pry easily under one of the front 2 screws to get it off
Jan 22, 2009 | 2003 Harley Davidson FLSTC Heritage...
1996 Lincoln Continental Rear Passenger seat belt retractor
do not touch,spring loaded and sealed ,renew only
Dec 19, 2008 | 1996 Lincoln Town Car
Busted drivers side spring. howdo you remove it safely
coil spring:
buy/rent a spring compressor.
hook it upside down over the second last coils of the spring(second last coil of the unbroken part) (bolt heads down and accessible) so that the compressor clears the spring seats.
Use all parts of the compressor.
Do up the spring compressor till it is just tight.
Put the car up on a 2 post, as the load comes off the suspension the spring will tighten in the compressor and flop around loose on the strut. Unbolt the top strut mounts. lower the axle until there is clearance and lift the spring off the strut.
Slowly take the tension off the spring compressor
Put the new spring in the spring compressor, (second last coils to clear the spring seats when reinstalling).
tighten the spring compressor, evenly and compress the spring, till it fits over the strut.
lift the axle, bolt on the top strut mounts, slowly release spring compressor, ensure top n bottom spring coils seat in the spring seats.
lower two post hoist
test drive
Always replace springs together as a pair
Jul 29, 2008 | 2000 Ford Focus
Philips DPM 9350 digital audio recorder [Digital Pocket Memo]
The spring release assembly is very cheap and should not cost you more than 25$ even if you get it repaired so i advice you take proffessional assistance..
Nov 02, 2007 | Baby Gear
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
