Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
-FC- and probe flashing
My oven continually flashes "probe" which is not so bad because I can still cook. but sometimes it will continually flash "-FC-" which is bad because then I can't cook. What should I do?
  • Mattchewman May 14, 2008
    I have the same problem with the fault code FC. I am going to replace the temp sensor and hopefully that will Fixya.
  • 126 Answers
FC replace oven temp. sensor
Posted on Nov 23, 2007
Ov300g flame no call for heat
The ignition module could be faulty, could be a loose wire, bad control board, bad temp probe, this is something you'll want a technician to take a look at, you'll spend more money trying to fix it yourself.
Feb 24, 2012 | Baxter OV300G Stainless Steel 27817 Watts...
Flashes f-3
you have a bad oven temp sensor probe
Jun 19, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Not heating and light flashing
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
May 27, 2009 | Sharp R-1480 Microwave Oven
Thermador double oven / Bake wont work /FC code flashed once
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
Aug 30, 2008 | Thermador SC272T Electric Double Oven
Oven will not unlock
Fault Codes
“Bake” or “Lock” may flash rapidly in the display to alert you if
there is an error or a problem. If “Bake” or “Lock” flash in the
display, press CANCEL pad. If “Bake” or “Lock” continue to
flash, disconnect power to the appliance. Wait a few minutes,
and then reconnect power. If the flashing still continues,
disconnect power to the appliance and call an authorized
servicer.
If this does not work let me know please.
Mar 06, 2008 | Maytag PER5705 Performa Electric Kitchen...
Stove controls beeping and flashing "Probe"
Most likely oven sensor / probe is the problem. It can be tested with an ohm meter. Not sure about your model, but most should read around 1100 ohms at room temperature. If there's a tech sheet somewhere on your unit, it should tell you.
Sep 23, 2017 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
237 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
