Question about AOC Nspire N22 Monitor
Restarted computer and now have blue hue. changed cables from analog to digital (tried two cables), reinstalled graphics card driver, no luck. Monitor is less than year old. Wondering what problem could be.
    Novelist:
  • 108 Answers
My first thought would be a bent pin.
Check both ends of the VGA cable to see that none of the pins are folded down, or missing, also be shure your graphics card is seated into the motherboard fully.
I know Analog should bypass any pin problems, but I've had pins that break off and get stuck in the video card, then cause more problems.
Good Luck.
Posted on Jul 28, 2009
  • 724 Answers
Both ends of the analoge cable at monitor and computer was checked?
Monitor onboard adjustments?
last but not least yea try a monitor
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Try moving the cable around...
try another monitor
You could also try opening your computer and taking the video card off and putting it back on... Don't do this if you are not sure that you can :)
Turned on computer today and my screen is blue green, does not change using monitor buttons?
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Apr 11, 2015 | AOC Computers & Internet
I cant get my new xfx adeon hd 5450 to install on my asus motherbord p5ple-le i have try disable onbord video no luck and i cant find any help with this mother board some one help me install this car i...
the drivers might not be installed correctly you might have to uninstall the graphics card restart your computer then reinstall the graphics card and its drivers
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if you physically remove your video/graphics card restart your computer then reinstall it this should activate the found new hardware wizard
make sure there is no dust built up or in the video card socket
if you need more help with this post a reply
hope this helps you
Aug 20, 2011 | ASUS A8N-LA GeForce 6150 LE Socket 939...
Analog output cannot display video mode
Hi, there!
Please check the connection of DVI or VGA cable which connect between your computer box and monitor. Check at the back of your computer box, how many VGA ports(the blue port)? If your computer box have 2 VGA ports( one in-built on-board and one from added graphic card), always connect to the one from added graphic card, not the one on-board. Hope this help. Thanks for readin.
Jul 11, 2011 | Dell Monitors:Dell 1801FP Driver
Blue hue on computer, but not caused by the monitor. Does it come from the graphic card?
Yes probably it came from the graphic card, you should try cleaning it or reconnect it to your computer, if cleaning and reinstalling doesnt work, then you have to buy a new one.
Jan 07, 2010 | Dell C521 DimensionTM PC Desktop
LG Flatron W2252TQ 22'' monitor not working in digital mode
try to set your screen resolution to maximum using Display Settings in windows. Besides, are all software drivers for this monitor loaded and properly installed? Right click My Computer=>Properties. select hardware => device manager. Make sure video icons are not marked with question marks. if they are, install monitor drivers shipped with your monitor.
regards!
Jul 26, 2009 | LG W2252TQ Monitor
Monitor says No signal digital
Is ether the monitor or video card uses both DVI or VGA port. There may be a switch on the graphic card that changes it from DVI to VGA, often outside the card.
Also is the computer monitor set to the right setting if it can use both VGA and DVI, if using DVI (of any type) it need to switch to digital, and if using VGA it need to be set to analog. This may be a physical switch or using the settings button. (see manual how to change them)
PS: VGA port is a blue D shaped port with 15 pin holes, and DVI is a white rectangle port with one port being a line.
Mar 17, 2009 | ViewSonic VG2030wm LCD Monitor
Capture driver present in Device Mgr but ATI card says no
hi,remove the drivers restart, shutdown relocate the card to different pci slot, reinstall the drivers, then try again hope this helps,good luck, if you have the install disk use that, then go for newer drivers.
Feb 13, 2009 | ATI ALL-IN-WONDER X600 PRO, (256 MB)...
My graphic destroyed
your video card has failed, you will need to reinstall your drivers or possibly even replace it.
Dec 09, 2008 | MSI (MS8936340) (64 MB) Graphic Card
Problem
uninstall ALL video drivers reboot computer should reboot with standard windows video drivers does the screen still play up if so you may have faulty video card.let me know please
Jul 17, 2008 | ATI Mobility RADEON Graphic Card
AOC Nspire N22 Monitor Logo
104 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
