Question about Dell Inspiron 6000 Notebook
Toshiba Laptop Screen
I have a Laptop and a chime fell on the screen. The screen is not cracked but when you turn it on the screen is now white with rainbow colored streaks going down the middle. And on the far left side you can see a black screen with white letters on it but not enough to read it. What do you think the problem is?
  • 3 Answers
Ur right the chime did it the screen ddnt crack but the piments in side are all jumbled ... the same happened when a relative got in a car accident... replacing will b needed tho
Posted on Jul 28, 2009
I drooped my laptop
If the glass isn't cracked, it may be a poor contact with the screen supply. It may be a damaged screen. Job to tell without taking it apart.
Feb 01, 2014 | Acer Aspire Computers & Internet
Toshiba satellite pro p100 screen problem
The LCD can be replaced. The part is around $50-$75 I believe. It can be tricky to replace, but if you take your time, you can save money by doing it yourself. The screen sounds cracked or broken, and black & white will not work either.
good luck
Mar 19, 2013 | Toshiba Satellite P100 Series / Satellite...
Toshiba AA67-00136B
It depends on the model---older rear projection sets maybe---newer LCD or Plasma---NO----cracked or damaged screen on those is the end as part costs are more than set was new.
Mar 21, 2012 | Toshiba Televison & Video
I only have a white screen,connect to another moniter still no screen.
What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following:
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
1-laptop-white-screen.jpg Here's an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
Most likely you still can use the laptop with an external monitor. Just connect the monitor to the VGA port on the back or side of your laptop and then switch the video output from internal to external mode.
On Toshiba laptops you can toggle between internal and external screens using Fn+F5 keys. Hold down Fn and press on F5 until you get video on the external monitor.
On IBM laptops use Fn+F7.
On HP laptops use Fn+F4.
It's possible that you have to use a different key combination on your laptop but you get the idea.
On some laptops, in order to be able to use the external monitor, you have to connect it to the laptop and then restart the laptop so the external monitor is detected by the laptop.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you'll have to take apart the display panel because the connector is located on the back side of the LCD screen.
These laptop service manuals and disassembly instructions may be useful.
4-reconnect-video-cable.jpg I always check the video cable connection first. Reconnecting the video cable may fix your problem.
If reconnecting the video cable doesn't help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen.
7-white-lcd.jpg After I assembled everything back together and connected the original LCD, it's still white.
CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced.
For more information:
http://solvetheproblemhere.blogspot.com/2011/05/laptop-lcd-screen-turned-white.html
May 10, 2011 | Samsung N150 Notebook
When i power on the laptop nx 6110 it brings a white screen on the LCD.
May 09, 2011 | Compaq NX6110 TFT XGA Notebook
Ok so here is what happened play by play i was listening to music on my bed with my laptop i fell asleep with the screen shut i woke up an dwent to go turn off my computer and whaen i opened the laptop the...
you have either,
cracked your laptop screen
or
the ribbon cable has come loose,
Either way you will need to take off the front of the laptop screen plastic bezel
remove the screws
detatch old screen,
if the screen is cracked replace the screen
if there is no cracks then check that the ribbon cable didnt come loose
u can put it back in and check the screen works before putting the front bezel and screws back in
If you are not confident ask a laptop repair guy to do it for you
i fixed one last week for a client,
it was £88.70 incuding VAT and special recorded delivery (with insurance)
screen arived next day and took me 1 hour to fit
I charged the lady £45 to fit the screen
So if you want to save money do it yourself
You can find Youtube videos explaining how to do it, thats what i did
I am a PC repair guy, but i had never had to fit a screen before
I had no problems whatsoever fitting it
the hardest part for me was getting the front plastic bezel off and then back on at the end
goodluck hope this helps you please rate me
thanks
Apr 08, 2011 | Computers & Internet
I replaced a cracked lcd screen on my wife's toshiba netbook NB205-N313/P. First let me describe what happened. The netbook fell and the screen cracked and I connected to an external monitor and had to...
Check the ribbon-cable between the motherboard and the LCD screen. It is not transmitting 100% of the video-information.
Be sure that it is not "crinkled", and that it is tightly connected at each end.
Sep 10, 2010 | Toshiba Mini NB205-N313/P Netbook
My laptop went to white screen every time when I on it. How to solve....my laptop -- aspire 4710z -- almost 2 years but it happened JUST it 4 mths.....
Hi..
Your problem are related with my laptop problem, but i totally fix it with my own. From my experience I can tell that this problem may be related to the following:
1-laptop-white-screen.jpg Here’s an example of a laptop with white screen. When you turn on the laptop, it starts but the image on the screen is completely white right from the beginning. In my case it was a Toshiba Satellite M45 laptop but this problem may occur with any other brand.
It’s possible that you have to use a different key combination on your laptop but you get the idea.
3-video-cable.jpg I noticed that in some cases the laptop screen may turn white because of poor connection between the video cable and the LCD screen. If you want to check this connection, you’ll have to take apart the display panel because the connector is located on the back side of the LCD screen.
If reconnecting the video cable doesn’t help, most likely you have a problem either with the LCD screen or with the motherboard.
5-disconnect-lcd-screen.jpg The best way to find out witch one is causing the problem is testing the laptop with another working LCD screen. Without this test you’ll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You’ll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video.
6-test-with-another-lcd-screen.jpg For this purpose you using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
7-white-lcd.jpg After I'm assembled everything back together and connected the original LCD, it’s still white.
That's my laptop brand and model, and i am searching an image regarding about my problem. This problem are common to another brand.
Hope it may helpful for you!
Good luck
ICmanServer
Jul 31, 2009 | Acer Aspire 4720 Notebook
Toshiba laptop cracked screen
you can use external monitor, but best option is to replace the cracked screen. Take a tour of toshiba service centre.
Thanks and Good Luck
Iqbal
Jun 26, 2008 | Toshiba Satellite L25-S119 Notebook
Cracked screen
rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
Oct 12, 2007 | Toshiba TE55T11 55" Rear Projection...
Dell Inspiron 6000 Notebook Logo
205 people viewed this question
Alun Cox
