Question about Dryers
Drum starts but does not continue
Dryer Model DWSR 483 GBOWW drum starts but does not continue, stops as soon as start switch is released
  • 1,543 Answers
You have one of two possible problems. 1. The run winding in the motor, or wiring to it in the motor switch is bad. = get a new motor. Or, more likely: 2. The internal centrifical switch in the motor is not moving back into the non-running position. (this results in only the start winding being energized when start switch is used.) Usually = get a new motor, but you can try to lube it up and get it moving again. You will have to open dryer top to be able to take dryer front off, then remove belt so you can remove the drum to get to the motor. Look inside the motor near the belt end. There is a collar on the motor shaft with springs on two sides of it. That collar needs to be free to move back and forth. (only about a 1/2 inch or less) Sometimes a bit of spray lube and a little manual moving of the collar is enough to free it up and save you the cost of a motor.
NOTE: Do NOT try to run dryer with using only the start switch held. You will burn out the start winding.
Posted on Jul 29, 2009
Drum not turning
That is a bad sign. If the buzzing starts when you press the start button and stops when you release its almost safe to say that the motor has a dead short or grounded out and causing that to happen. You can check the start switch by getting a multimeter and with the dryer unplugged take the wires off the switch, place a lead on each pin and press the start with meter set for continuity. If it shows continuity when presed and stops when released your motor is shot and needs to be replaced.
Now if you press the start button and the machine starts to hum and continues to hum its possible that something has gotten caught in the blower wheel and binding the motor up. Depending on the make and model the location and access to it vaaries.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 06, 2012 | Kenmore Dryers
My dryer will only run if i hold in the door switch button and turn the drum while i hit the start button.
Jun 04, 2012 | Maytag Dryers
The drum in my kenmore elite he3 wont turn
May 08, 2012 | Kenmore Elite HE3 Steam 8674 Dryer
I have i kitchen aid gas dryer,when i press the start button it makes noise for about 3-4 second s then it stops and it won't start
Feb 27, 2012 | KitchenAid Dryers
Kitchenaid gas dryer started buzzing when door is shut
May 17, 2010 | KitchenAid Dryers
Dryer runs about 5 seconds, buzzes and stops
Apr 19, 2010 | KitchenAid Dryers
Dryer makes a loud buzzing, drum starts turning then stops. If i wait it will repeat
Mar 28, 2010 | KitchenAid Dryers
GE electric dryer (model #DDE5300BBLAD) won't start when I hit the start switch. I do hear a noise when I hit the start switch...stops when I release the switch.
the sound you hear is the motor trying to start.reach in drum and turn clockwise 1 revolution.try to start it again,if it starts your motor is starting to go bad and will have to b e replaced soon.if you canrt turn thje drum you probably have something stuck in blower below lint filter .hope this helps .please rate my response:)
Dec 09, 2009 | GE Dryers
Model 63942101 Dryer Starts\Stops after Start buttton released.
Sounds like a bad door switch. Thats about all it can be. I see this from time to time but not often.
Please rate solution.
Aug 26, 2009 | Kenmore 63942 Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
