Question about Yamata FP202L Cordless Iron with Auto Shut-off
The steam on my FP-202L stop working. I believe it may be caluicm buildup, even though I use distill water. How do I clean the caluicm out?
    Novelist:
  • 108 Answers
I've heard that Vinegar is the best for water applicances, like steamers, coffee makers, Irons, etc.
Try rinsing it out with vinegar.
Posted on Jul 28, 2009
What type of water should I use. Tap or Distilled?
Tap or Distilled Candice, Distilled water preferred, but yes you can use Tap water. You may just have to run a mixture of vinegar and water to clean deposits every 3 to 6 months through the iron which may have to be done even if you use distilled water.
Check the attached links,instruction and guides on steam irons. Good luck .
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clean Your Iron DoItYourself com
How to Clean Steam Iron
Thrifty and Chic DIY Projects and Home Decor
Apr 07, 2016 | Rival Irons
I cannot get my GCSBDS212 steam iron to make steam.
Have a look at the steam holes in the bottom, they should be nice an clean with no blockage. If they are blocked up you will need to remove the calcium buildup inside the iron. Get some LimeAway at HDepot, pour it into the water reservoir, let sit overnight. Next day turn the iron on and try steaming on some old papers covered with an old rag or towel, once it starts working steam for a few minutes, then unplug, drain it, put in clean distilled water and flush it out until the steam comes out clear. Use distilled water not tap water, it has much less mineral content and will be less likely to plug it up. Most pharmacies and Walmart sell distilled water. ! gallon about $1.25.
Feb 05, 2015 | Sunbeam GCSBDS-212 Digital Steam Master...
How do I clean a kenmore model number 100.8058880A steam iron
Try putting in some LimeAway (Home Depot carries it) and let it sit overnight. Then turn it on to steam and press the steam button to get the steam through the bottom holes etc. Do this on top of some old rags. Then do it again with just water to clear out the LimeAway, should get most of the calcium out. One tip use distilled water in it instead of tap water, you'll get much less buildup. Get distilled water at any retailer about $1 per gallon.
Jan 01, 2015 | Kenmore Irons
Floor steamer not getting hot
follow this steps and fix it.
GOD BLESS YOU
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Sep 30, 2013 | Conair Compact Garment Steamer Iron
Mineral buildup in my steamer
To eliminate mineral deposits and prevent corrosion on your steam iron, give it an occasional cleaning by filling the reservoir with undiluted white vinegar. Place the iron in an upright position, switch on the steam setting, and let the vinegar steam through it for 5-10 minutes. Then refill the chamber with clean water and repeat. Finally, give the water chamber a good rinsing with cold, clean water.
-From Reader's Digest 150+ Household Uses for Vinegar
Jul 16, 2012 | Rowenta Irons
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    How to clean brown water coming out of iron
    The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
    Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
    If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
    Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
    Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
    The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
    Apr 09, 2010 | Rival IR620 Iron
    CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
    Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
    Dec 04, 2007 | Rowenta DX6700 Iron
    Steam doesnt work
    A mineral buildup from your water may be blocking the holes in the soleplate of your iron. Before you do anything, read the instruction booklet for your appliance or call the manufacturer. The old remedy of using vinegar to unclog an iron is no longer recommended for many models. Some manufacturers suggest alternating tap and distilled water in the steam compartment to avoid a mineral buildup; others recommend using a specialized cleaning product (available at fabric and grocery stores) to clean the soleplate.
    Nov 17, 2007 | Sunbeam 4214 Iron
    Yamata FP202L Cordless Iron with Auto Shut-off Logo
    109 people viewed this question
    Top Yamata Irons Experts
    Are you a Yamata Iron Expert? Answer questions, earn points and help others
