SOURCE: need to replace rear housing bushings on
yes bushings are available that will cost around $60. no need to replace rear end.. i had the same exact problem. . good luck
SOURCE: how to replace a rear strut bushing on a 1998
yes u need a compressor , becareful when you are doing it
SOURCE: rear spring bushes, (front of leaf spring) navara
Throw me an email at [email protected]
and I'll email you a copy of the Service manual for the Nissan Maxima 04, I have it as a WinRar compress document and also can be extracted using WinZip and so you'll ve able to see it as PDF to view and print out the only section u need, you'll have diagrams for all electrical to mechanical.....
The fast you do it the fast you'll get it....
SOURCE: replace rear swaybar bushings
Yes, it is quite easy. These bushings are a very common source of rear end rattles. Remove the bushing retainers, replace the bushing, and then the retainers and bolts. Torque is low, 14 ft-lb
SOURCE: 2004 HONDA CR-V STRUTS OR BUSHING
a bumpy ride indicates that the shocky in the strut is failed
replace the inserts in the strut housing
do both sides
check out the bushes for the stabilizer bar and suspension mounts
