Question about Sharp AR-207 Copier
I am getting error code F9. what does this mean?
  • 313 Answers
F9 codes usually relate around the printer boards or firmware errors you could try uipdating the firmware of the sharp site or look at the printer board connections.. try unplugging machine from wall and then take the back panel off check the conections of the boards and reboot.
Posted on Jul 31, 2009
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
F9 error
the F9 error code means that you have a problem with the door latch assembly in your range. The specific technical information on this failure in your model of Frigidaire range is shown in the image below. If you can clear the F9 by using the troubleshooting steps shown below then your range may resume normal operations. If the CLEAR key does not eliminate the F9 then you will need to try unplugging the range for 30 seconds. If the F9 returns when you plug the range back in, then you will need to replace the door latch. Here is that part to order.
To continue to troubleshoot this problem yourself, then you will need to unplug the range and check the wiring between the door latch assembly and the electronic oven control board. Remove the back panels to access these components. NOTE: Internal metal edges and the sides of the back panels can be sharp.
Feb 13, 2013 | Frigidaire PLEF398AC Electric Kitchen...
It's displaying an error code - F9-2. What does that mean?
Hi lyndakh7,
The F9:-4 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Sep 01, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I was baking at 350degrees. My oven turned itself off and the error code F9-3 is flashing. please assist if abe.
The F9-3 error code means that either of the two oven self clean latches is stuck so ya need to check and see in both ovens if their is something from obstructing the lacth
if you also get a F9-4 that would mean its just the lower oven
a F9-5 would be just the upper oven
but for the F9-3 it could be either oven
Aug 28, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I get an F9 error message when I try to set the oven to bake.
THis is what the F9 error code means;
F9 Door latch failure Replace door latch switch or assembly if necessary
Aug 20, 2011 | Ovens
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
F9 CODE OVEN WILL NOT HEAT.
Hi
Thanks for using FixYa. Error F9 means door latch failure. To resolve this issue you’ll have to check the door latch and replace the door latch and/or assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Amana AOES3030 Electric Single Oven
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Sharp AR-207 Copier Logo
471 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
