Question about Whirlpool LEQ8000JQ Electric Dryer
I'm trying to remove heater element from Whirlpool dryer
I'm trying to remove heater element from Whirlpool electric dryer AWZ555. It's located in the back center, against the back of the drum. All photos online show it along the lower right ahnd side, but this is in an aluminum closure against the back and I can't figure out how to get in to replace the element. Any tips? It's driving me mad.
  • 13 Answers
The element is held in place by 2 8mm bolts and once removed the element will slide out.
Posted on Jul 29, 2009
Where is the igniter located on dryer
An easy answer: gas (natural gas) dryers have igniters, but your electric dryer has no igniter,
instead it has a heating element (a zigzag arrangement of wires similar to that found in a space heater). Remove the back of the dryer - the heating element will be enclosed in an air duct that feeds heated air into the drum via a vent at the top back of the drum.
If you look into the drum, you can see the vent cover that covers the heated air inlet at the top back of the drum.
Sep 12, 2011 | Whirlpool LER4634J Electric Dryer
My whirlpool leb 6000 pqo will not heat
check heating coils, high limit, temp selector switch.
Apr 05, 2011 | Whirlpool Dryers
The dryer turns on, and tumbles. Yet it no longer get hot. I was thinking heating coil. But was told it could be a smaller part.
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The first thing to look at is the thermal cut-off which cuts power to the heating element when it blows due to the failure of the high-limit thermostat both located on the heater housing. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Roper REX3614KW Electric Dryer
I HAVE A RED4340SQ1 ELECTRIC DRYER WHERE IS THE HEATING ELEMENT LOCATED
The heating element is located at the rear of the dryer behind the rear access panel. Disconnect power then remove the screws attaching the rear access panel to the cabinet and remove the panel.
Your dryer seems not heating but it doesn't mean the heating element is busted. The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components. Click on the link below for the detailed procedures.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 27, 2011 | Whirlpool LER4634J Electric Dryer
I have a Whirlpool Electric Dryer that is running but will not heat up. I suspect the heating element has failed. The Model Number is LEQ9508PW1. Please detail for me the location of the heating element...
unplug unit remove front lower panel . on the right side you will see the heater box element is held in place with a small screw on front left side and friction hold outer housing with hand and pull out element with a pair os pliers.
Aug 02, 2010 | Whirlpool Dryers
How do you replace the heat element on a whirlpool LER8648 dryer?
Before replacing the heating element, check first the continuity of the thermal cut-off and the high-limit thermostat located on the heater box, the resistance of the heating element, and the continuity cycling thermostat located on the blower housing. Replace the heating element only when it reads open. Replace both the thermal cut-off and the high-limit thermostat should any one of them is found open. The cycling thermostat must have continuity between its thicker terminals; otherwise, replace it.
All of the above components are accessible through the rear of the dryer. Remove the rear panel by removing the screws securing i to the dryer cabinet. Replace the heating element by removing the screws attaching its housing to the heater box then securing the new heating element housing in place.
May 28, 2010 | Whirlpool Dryers
Where can i get a heating element part # ao4415 for whirlpool dryer model # ler8648pw0. We removed the element and it appears to be burnt out.
HI. I have located a replacement heater assembly for your unit. Kindly, click the link below to access the purchase site.
CLICK HERE
You can order from the site link above.
Jan 17, 2010 | Whirlpool LER8648P Electric Dryer
Instructions to replace faulty heat element on a whirlpol electric dryer
If the model number is correct, the heating element is replaced by following these steps:
1. UNPLUG the dryer. Dangerous voltage still exists inside the unit even when it is shut off.
2. Turn dryer around so you can access the rear panel. Disconnect the dryer exhaust vent hose.
3. Loosen and remove all the screws around the perimeter of the rear panel. Remove panel and set aside.
4. The heating circuits will be located on the right hand side (as viewed from the rear) with the heating element located inside the heater box.
5. Remove the mounting screws that hold the heater box in place and disconnect the electrical connections (make sure you annotate where the wires go).
6. The entire heater box comes off with the element inside. Loosen the screws on the outside of the heater box that hold the element in place. With the screws removed, the element will slide out the bottom of the heater box.
Now...if the dryer is running but not heating, have you confirmed the heating element is bad? There are several factors that can cause these symptoms. Please review the following link before you assume the element is the cause:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If you haven't done so already, it may be a good idea to double check the source voltage, followed by a check of the Hi-Limit Thermostat and Thermal Cut-Out (TCO). All these components can factor into the same symptoms you may be experiencing.
If you have any questions, please post back and let me know. I hope this information is helpful to you.
Dec 05, 2009 | Whirlpool LER5636P Electric Dryer
Location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
Apr 20, 2009 | Whirlpool LEQ9858L Electric Dryer
DRYER SPINS BUT WILL NOT HEAT
The heating element is located in a pan on the rear wall of the dryer. You must remove the front and drum to access it. Start by opening the door and removing the screws that hold down the top. Then you can easily get the front off. In a GE dryer almost 100% of the time it is going to be the heater element.
When restringing the heater...READ MORE
Mar 19, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
100 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
