Question about Whirlwind FH-778 Air Conditioner
Portable a/c - water drains out the bottom not into drain tank
Everstar - modelMPA-08CR - ONLY 3 yrs. old. On a waiting list for estimate and repair. Only two repair shops given by manufacturer and only one response.
    President:
  • 1,922 Answers
Where are you located,i'm in wisconsin and do A/C repair,and is it warrantied yet???
Posted on Jul 30, 2009
Bottom Plug Leaking Water Tank Bone Dry /Everstar mpk cr 10000btu
you said that it has not been used for 3 yrs then maybe the tube leading to the water drain is clogged. try to clean it
Aug 21, 2009 | Danby DPAC8020 Air Conditioner
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
Everstar MPA 08CR Portable AC unit. Water full
Your float switch is faulty, replace.
Jul 02, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
My air conditioners is a everstar model mpa-08cr, and i need to instal the water hose on the side of unit.
Hey there, just follow these simple steps then you'll be on your way
To connect the continuous drain option. Remove
the water tank from the cabinet. Inside the
cabinet (water tank area) you will find a section of
hose hanging beside the water tank, which is plugged
at the end. Remove the plug
from the end of the hose and install the drain hose connector
(included with this unit) into the
end of this hose section. Route the end of the
hose (with drain connection) into the water tank,
then through the hole provided in the face of the
water tank. Attach a section of garden hose (to
suit your continuous drain option requirements)
to the drain hose connector. Place the open end
of the hose directly over the drain area in your
basement floor.
Please make sure the drain hose
section routed through water tank does not interfere
with the correct positioning of the water tank inside
the cabinet, or the will fail-safe switch mechanism will
be activated, not allowing the unit to operate.
Jun 19, 2009 | Danby DPAC8020 Air Conditioner
I have a portable air conditioner and the water condensation tank fills in about 4 hours of constant use. Is there any kind of portable water tank that I could attach to my unit that would allow me to...
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Jun 11, 2009 | GE APN10AA Portable Air Conditioner
Everstar portable ac unit displaying error message P1. The unit turned itself off and will not come back on. It had no symptoms of not working well before turning off.
According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
Mar 25, 2009 | Heating & Cooling
Everstar portable air conditioner
IF ANYONE NEED TO SEE THE OWNERS MANUAL FOR THE
EVERSTAR PORTABLE AIR CONDITIONER
MODELS # MPM2 - 10CE - BB6
MODELS # MPM2 - 10EE - BB6
MODELS # MPM2 - 10CR - BB6
MODELS # MPM2 - 12CE - BB4
MODELS # MPM2 - 12EE - BB4
MODELS # MPM2 - 12CR - BB4
YOU CAN E-MAIL ME AT - RICHCPZ@YAHOO.COM
I'LL SEND IT TO YOU IN A PDF FILE
(AS LONG AS I DON'T LOOSE IT IN MY COMPUTER )
Sep 08, 2007 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
146 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
