It is a small Keurig machine
SOURCE: keurig platinum brewer says "not ready"....will
sounds like a bad machine, you can try contacting Keurig directly and see if they will honor the warranty, if that doesnt work i know of this great website that sells all kinds of keurig products and parts for very cheap.http://stores.ilikenew.com
SOURCE: All LED lights flashing and the brewer does not work
I had the same problem. They told me it had to be "reinitialized" To do so, press the auto-off, small, and large cup buttons simultaneously then release. All lights should go off. Unplug, replug, then press power and it should work again.
SOURCE: Keurig machine says "Brewing" but only a small
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: My Keurig Brewer is flashing the add water,
Perhaps more than one problem people are dealing with but here's what I found. The round float in the tank is magnetic so it's either activating some crappy mechanical switch or more likely a hall effect sensor. Remove the tank and dump the water so the float will rise from the bottom when you refill it. Take a good strong magnet and slide it around the side of the unit where the float would be, tapping it as you go. Put the tank back on and fill it. One try and I was back to making coffee.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
heatman101
Keurig
heatman101
heatman101
heatman101
'lll
