Question about Maytag Dependable Care LAT9706
Washer now leaking and shaking...
Mine shakes and now leaks intermittently. Anyone experiencing the same?
  • 3 Answers
Bearings are shot. I think there's a overhaul kit but thats what it is. Had same issue. get the agitator out with a socket wrench from the top and you'll see the various collars bearings etc.
Posted on Sep 15, 2009
My new lg washer delivered today is leaking water into the pedestal also is noisey and shakes
did whoever set it up, remove packing bolts from the back? is it leaking from hoses on back of washer, or from internal? check front panel on lower left from of washer. is filter accesses tight?
Mar 03, 2015 | LG Washing Machines
Kenmore 3.5 cu ft front load quiet tumble action washer. Will not stop cycling, leaks, and shakes violently when spinning.
The shaking could be due to a defective drum support bearing. The shaking also could have caused the door seal to fail, resulting in the leak.
Jan 22, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
I have a HotPoint washing machine, and it is leaking water bad. It leaks whenever the spin cycle starts, and the washing machine shakes pretty bad in that cycle. It's my ex girlfriends washing
The leaking could be coming from the exit port on the washing machine. Check the hoses leading from the washer to the drainage port in the wall. As for the shaking, check that the level adjustments at the bottom of the machine are level.
Apr 12, 2013 | Maytag Ensignia 3.3 cu. ft. Top Load...
2004 porsche cayenne turbo starts and then immediately shuts off
That's a lot of coolant to lose in that short amount of time- especially with no visible leaks. It sounds like you might be losing coolant to the cylinders which could be from a bad head gasket or a cracked block. Good luck, let us know what it was!
Nov 29, 2012 | 2004 Porsche Cayenne
Shaking while driving
The shaking can be the brakes, rotors, tires, poss alignment or wheel balance. It may also be connected to that CV boot that is torn and leaking which affected the axle. It has to be lifted & checked out. Good luck
Mar 08, 2017 | 2005 Dodge Ram 1500
Model CTS90AWN Speed Queen from Alliance Laundry Systems. The unit shakes / vibrates quite a bit - I have read that this is a common problem. Also leaks a small amount of water from beneath unit (have not...
These machine like to be loaded to capacity. Under loading them is the major cause of shaking. Try loading the drum all the way lightly filled but not packed. Another thing to look for is that it was installed properly. It is very important with theses machine that they be leveled properly at install. If this was not done shaking can occur.
Dec 27, 2010 | Speed Queen CTS90AWN Front Load Washer
I have a check engine intermittent light with some shaking in the engine also intermittent, also air bag light comes on intermitently.
Something shaking is almost always a cylinder misfiring.
Which is usually a bad plug or wire. But it could also be an intake manifold vacuum leak.
Jun 07, 2010 | 2002 Jeep Liberty
Washer Shaking Violently on Spin Cycle
Yes, there is...The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength for leaking issues Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 24, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool Duet Washer 8500 Dispenser Leaking
Ok try not to pull the dispenser too far out. When you pour the liquid detergent in the dispenser I belive it should say in the cup. For the shaking if the washer is not on a solid surface like a cement floor it will shake and walk if the floor is weak. Also make sure the delivery guys removed the 4 shipping bolts in the back. If the dispensor still leaks call for service bucause its new. Also some stores will exchange it if there is a problem within 30 days.
Jul 12, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
