X box 360 has got 1 red light on and it says e74 displayed on screen
This indicates overheating and could lead to terminal problems in the console... I would send it to MS for repair... also see this link if you like....
http://ezinearticles.com/?Xbox-360-E74-Error---Everything-You-Wanted-to-Know-About-Error-E74&id=2613185
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
