Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Krzr k1m won't connect to bluetooth device
My phone (krzr k1m) will pair with my moto h350 bluetooth headset, but then it won't connect to it... just keeps searching and never connects. Any ideas?
  • 7 more comments
  • mikerob Nov 26, 2007
    Bluetooth only connects once with my car. The it will not connect.
  • E Brown Jan 11, 2008
    I have the same exact problem. My KRZR K1m will pair with my Jawbone, but will not connect. It just times out.
  • tigerjeep Apr 15, 2008
    I have the same problem, I have 3 bluetooth now, and none of them will connect, I went to verizon store, they sent me a new phone same model, and bluetooth worked for 2 days, then stopped connecting, Im about to throw this phone out the window....HELP!!! PLEASE!!!! thank you christina,
  • Anonymous Jun 04, 2008
    SAME EXACT PROBLEM on my Krzr (verizon) .........
  • karrib Jun 23, 2008
    I had the same problem. I have a krzr km1 and the phone would not connect with my bluetooth, and buttons did not seem to be working. Tech support could not help me. After removing the micro-sd card everything worked as it was supposed to. I put the micro-sd card back in and it still is working. What's that about???
  • Anonymous Oct 24, 2008
    Same problem, bluetooth worked then the next day would not connect.
    My KRZR did have a microSD card installed. I removed it following the posted solution and now the bluetooth device connects to the phone. Will see if it happens again.
  • pavanj Nov 15, 2008
    hi how can i get bluetooth connection to krzr k1
  • Anonymous Mar 21, 2009
    how do I pair plantronics 220 blue tooth headset to krzr k1? I don't have an SD1 card in it.
  • donkan3 May 11, 2010
    Solution link . . . http://www.MOTOKRZR K1.com`
Turn off the phone. Remove the micro-sd card. Restart phone. It should connect now.
Posted on May 12, 2008
It didnt work
Posted on Oct 17, 2008
1) Turn off the phone
2) Remove the Micro SD card
3) Turn on the phone
4) Goto bluetooth setting and turn off the bluetooth
5) Turn off the phone
6) Put back the Micro SD card
7) Goto bluetooth settings and turn on the bluetooth and pair the headset
These steps are what I do. I have to take these steps whenever I remove the Micro SD card for file transfer to my computer.
Posted on Jun 21, 2008
Take out the battery for about 5 min and put it back in and it should work.
Posted on Apr 16, 2008
  • cdrhi Aug 30, 2010
    It worked so power off, remove sim. connect up. Phone tools should recognize your phone name and then you connect ask you to verify pin code/etc/etc and your on your way.
  • nappz Dec 30, 2010
    Good advice... was just about the throw this phone out. Thanks for posting simple and very useful information
    Problem Solver:
  • 5 Answers
From what I can tell and after researching the same issue it is the KRZR. I called both Verizon tech support and my bluetooth tech support.
There is no solution
If you notice some of the functions in the Blue tooth Pairing/connection menu functions don't even work. (The on off for instance and the settings) After it is paired. I tried my bluetooth with other phones and it works fine.
I am going to the Verizon store to complain untill i get a different model.
In short the KRZR software is defective
Posted on Feb 15, 2008
Trying to set up my motorola h350 bluetooth to my samsung s30 phone.
Turn your H350 on by pressing and holding the black "Talk" button on the side of your headset. Hold it until the blue status starts to flash. To turn the H350 off, simply hold the talk button until the headset turns off.
Pair your headset with your cell phone by entering into your cell phone's bluetooth menu--Menu > Settings > Connection > Bluetooth Link > Setup (see Resources below).
Put your Motorola H350 into pairing mode by holding the "Talk" with the device turned off. Hold the button until the status light on the side of your headset begins to flash, and turns back into a solid blue.
Back in your phone's bluetooth menu, choose the option to "Search/Discover" bluetooth devices. And when your phone recognizes your H350, select the headset and enter "0000" as the passcode.
Thank You
Sep 05, 2010 | Motorola Mobility H350 Wireless Headset
I have a motorola krzr k1m. It pairs with the t305 but, doesn't connect. Are they compatible?
These two devices ARE compatible. Sometimes you might be required to enter a passkey once your phone has paired with the T305 (in which case the initial value is set to '0000'). If this doesn't work try the Motorola website below:
http://www.motorola.com/Support/US-EN/Consumer-Support/Mobile-Phones/KRZR_K1_Default_Support_Loc%253AUS-EN#
And click on 'Car Accessories' under 'Connect my Bluetooth'
Hope this helps!
Aug 30, 2010 | Motorola Mobility Bluetooth Hands-Free...
I cannot connect my h350 headset to my phone how doi I do this
on your phone open your bluthooth section and(1) turn on bluetooth. then in the bluetooth options, (2)have your phone ready to search / find devices. (3)on the h350 press and hold the power button for about 5 seconds until the blue light comes on and stays on. it is now in paring mode. (4)tell ur phone to search for devices. your phone should find it. (5)then select the h350 on your phones found devices list. they will now pair. its possible a password will be requested, i believe the factory default password for the h350 is 1234. your phone password may be the same as your phone unlock code or your voicemail code.
time is limited you may have to do this a couple of times before they actually pair together.
Feb 19, 2010 | Motorola Mobility H350 Wireless Headset
Want to remove Motoraola H350 Bluetooth from MOTORAZRV3T phone
Hi
Try going into paired devices or active devices and delete from there
Feb 20, 2009 | Motorola Mobility H350 Wireless Headset
Pairing moto H350 headset
Try and change pass code for new one
Feb 14, 2009 | Motorola Mobility H350 Wireless Headset
How do I connect my h350 motorola bluetooth with my nokia 6275cel
Try video instructions on connecting Bluetooth headset to Nokia phones on www.HandBookLive.com under Electronics category (Motorola H710 headset). It should be pretty much the same for all headsets. Watch chapter on Pairing phone to headset (Nokia example) It shows you the steps and what the phone screen will look like on your phone as you go through the steps (activating Bluetooth option on the phone, then searching for devices (headset) and finally pairing the headset with your phone.
Dec 17, 2008 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
Bluetooth connection
first switch on ur mobiles bluetooth........... then switch on ur moto: H350...... then automatically ask to pair with the headset.......... accept it.............. then enter passcode 0000........... then it wil got paired........then answer yes to the next question ......... got it!!!!!!!!!!!!
Oct 28, 2008 | Motorola Mobility H350 Wireless Headset
How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Oct 26, 2008 | Motorola Mobility H350 Wireless Headset
V3 rzr h350
You do not have to unpair it from the other phone, the headset can be paired with many devices, but can only be connected to one device at a time. A safe bet would be to turn bluetooth off on your old phone.
Here is the User Manual for your h350 bluetooth, and pairing instructions are included. Enjoy!
User Manual
Dec 20, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
1,877 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
