Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
Cassette holder won't open
Brand new; just out of the box.  Power is on.  Media is on "tape" mode.  Eject button is slid forward.  Cover opens, but the cassette holder does not open.
  • 126 Answers
This happens because on the right side of mechanism is a push on switch and a metal plate pushes when cover goes out.If this is not working properly then no command exists to open the cas.elevator.Use a contact spray in this right side i mean the side of lens.If problem continues send it back to the shop...
Posted on Jan 28, 2010
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Eject button won't work
What is the unit? There are often times in these new systems a belt or gear mechanism that moves the head base as well as other parts around. As units get older they need lubrication and the grease hardens to where they do not move as well. Belts also stretch and need to be replaced. When the head base mechanism is up or the mechanical alignment of the mechanism is NOT in stop mode or eject position the door is blocked from allowing it to open. The solution is to open the unit up and release the tape by a orderly means and then to work on it or have it worked on by someone who understands these units.
Dec 16, 2012 | Audio Players & Recorders
Error 04: unit in safeguard mode, eject and reinsert tape. However, after I opened the cassette holder cover, the cassette holder didn't automatically open, and I can't get the tape out. I tried taking...
hi
i am dammika
from sri lanka
i have a jvc handy cam
but it broken display ribbon
i want by it in sri lanka
how can i get
pls send me a sms 0094778280849
thanks u
Apr 26, 2011 | JVC Video Cameras
Cassette stuck in Sony TC-K611S deck
Rotate loading gear with your finger until mechanism released and set on stop position. press eject button and take out tape.
Jul 01, 2009 | Audio Players & Recorders
Can not eject tape
I had same problem, while transferring media from TRV-16 to DVD, tape would not play, then would not eject. This after transferring several tapes to DVD. I tried several things over the last couple months that did not work before finally getting it open today. It did me no good to remove several of the outer panels that were each held by two "tiny" phillips head screws each. Went to the internet, found your post, also found a post that referred me back to SONY page which follows.......
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
"NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required."
After I did this, I could hear a whirring sound when I hit eject, although nothing came out. While the whirring was going on, I pulled up and out with constant pressure and the cassette holder opened. The tape had jammed apparently as the little protective plastic tape guard was jammed partially open when I pulled the cassette out. Good Luck and don't be afraid to put a little pressure on the door if you can hear the door trying to open.
Now I turn to recovering the tape, but having grown up with cassette decks, don't believe it will be a problem.
Oct 14, 2008 | Sony Handycam CCD-TR416 Camcorder
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Cassette jam
I had this problem, and here is how it was resolved.
My cassette would not pop out when I opened the door with the camera turned on. When I turned off the camera and opened the door, it slid out much further, but still failed to pop open so that I could remove the tape. Then it slid back in.
Remove the battery, and have the camera off, but make sure the power cord is connected. Open the door until the tape slides out further than at other times. (Note: It intermittently slides out further when the camera is off. Sometimes it will not slide out any further than when it is on.) When the tape is slid out as far as it will go, quickly remove the power cord. The tape will stay in the slid-out position. Now, at the bottom side of the tape door there is a curved channel for a small pin to slide in. This channel has a 90% curve at the bottom of the channel to catch the pin, which holds the door closed. Push that pin back a little (toward the lense) to get it to go around that 90% curve, and the door will pop open so you can remove your tape. The ribbon of your tape will be jammed in the camera a little, so you will have to be careful and move the ribbon around a little until you can get it out freely.
This worked for me twice. I did not try putting a tape in again.
I hope this helps.
Apr 10, 2006 | Canon ZR10 Mini DV Digital Camcorder
Cassette Jam
The most frequent cause of this type situation is not having a power source attached, or a depleted battery pack. Once the power source is available, some models require manually unlatching and opening the cassette compartment cover. When the cover is fully open, the videocassette will eject automatically. Please try the following procedures. 1. Attach the power source to the camcorder correctly or use a fully-charged battery pack. 2. Fully-open the cassette compartment cover until it stops while sliding and holding the OPEN/EJECT switch. The videocassette will eject automatically after a few seconds. If the videocassette still will not eject, seek assistance from a Canon Service Facility.
Sep 04, 2005 | Canon Optura 60 Mini DV Digital Camcorder
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
291 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
