Question about Logitech (980408) Wireless Headset
How to pair the device
Logitech express headset 980408-1120
Press 10s the "volume up" button
next on your mobile phone "search for a new device"
code is "0000"
press 5s the same button to activate connection when paired
press 3s same button to switch off*
regards
Posted on Dec 17, 2007
Go to Settings, then accessory settings, manage bluetooth devices, press yes to register it, start scanning, press and hold switch on headset until it blinks red and green, click it once found on screen then enter passcode "0000".
Posted on Aug 30, 2008
I pad Bluetooth won't link up with ipad sixth generation and Logitech slim folio
Tip & How-To about Miscellaneous
Pairing Bluetooth Devices Posters often ask "How do I pair my Bluetooth ???" Insert whatever device you have at the question marks.
Generally, you need to read the instructions for the camera, headset, speakers or whatever the Bluetooth device is.
Roughly speaking though.
Settings - Bluetooth - Search, on the Android, iPhone, Windows phone whatever.
With camera, speaker, headphones or whatever the Bluetooth device is, you have to press a button on that device to send out the signal. On my Bowers and Wilkins T6 Speakers, there is a button on the top with the Bluetooth symbol on it. This is the part people usually don't do and ask for advice, thinking it will do this automatically.
When the Android device recognises it, click Pair, and if it asks for a code, the Default is '0000', (four zeros, no quotes).
Posted by Andrew... on Nov 19, 2016
SLIM FOLIO Logitech Support
Apr 17, 2018 | Logitech Computers & Internet
Pairing rejected problem?
Make your device visible for a longer time so that you can enter the pairing PIN.
Sep 28, 2014 | Radio Communications
I dont have the code to my bh-602
According to the manual it is 0000
I added an excerpt of the manual here :
Pair the headset
1. Ensure that your mobile device is switched on.
2. To pair the headset if it has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light flashes blue quickly.
To pair the headset if it has been previously paired with another device, ensure that the headset is switched off, and press and hold the power key until the indicator light starts to flash blue quickly.
3. Activate the Bluetooth feature on the mobile device, and set it to search for Bluetooth devices. See the user guide of your device for instructions.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your device. In some mobile devices, you may need to make the connection separately after pairing. See the user guide of your device for details. You only need to pair the headset with your device once. If pairing is successful, the headset appears in the menu of the mobile device where you can view the currently paired Bluetooth devices.
Mar 21, 2011 | Nokia bluetooth headset bh-602
How to connect my nokia BH-104 bluetooth handsfree to loptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF,
then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Oct 29, 2009 | Logitech Bluetooth Wireless Talking Kit...
Pair usb logitech headset to ps3
On your PS3's main screen, scroll over to Settings.  Then scroll down to Accessory Settings, and select Audio Settings and adjust the input device.
Jan 10, 2009 | Logitech USB Headset for PlayStation 2
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Aug 07, 2008 | Logitech Mobile Freedom Wireless Headset
How to connect my mobile with my logitech handsfree via bluetooth
To connect:
- Make sure the headset is charged and turned off.
- Hold the multi-functional button for 7 to 10 seconds to set pairing mode. Pairing mode is indicated by de led flashing blue-red.
-Now connect from your phone by selecting discover devices, or something (do not own a L6i). It will find your headset.
-Select the headset and select 'pairing'. Passcode = '0000'
If pairing is successful, the flashing light will change.
Mar 27, 2008 | Logitech Bluetooth Wireless Talking Kit...
Logitech Wireless Headset pairing password
it should be "0000", i have also a logitech wireless (bought in france)
the only "system" button is "volume up"
press 10s to pair
press 5s to activate a bt connection
press 3s to desactivate the headset
Nov 26, 2007 | Logitech (980408) Wireless Headset
What is the default passcode for the Logitech F-0228A Mobile Freedom headset?
Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
Pair Your Headset
Before using, you must pair your headset.
1. Turn phone on.
2. With Headset off, push Talk/Volume up button for 10 seconds. Blue LED will flash rapidly.
3. Follow pairing instructions in phone-setup or connect menu. Your phone should find “Logitech
HS04VXX”Headset and prompt you for a passkey pin.
4. Enter “0000”.
5. Press OK on phone.
6. From Headset device list press “Logitech HS04VXX” Headset.
7. Select connect.
When your Headset is successfully paired, the blue LED will flash slowly.
Nov 11, 2007 | Logitech Mobile Freedom Wireless Headset
Logitech HS04 V01 connection
Try turning off the headset. Then setting your phone to look for bluetooth device. Touch and hold for ten seconds the larger button on the headset, should flash blue light rapidly. then command phone to find device, (commands differ from one phone to another). When phone "finds" headset blue light should change to intermediate flashing (three flashes every five seconds aprox.) Hope this helps..
May 08, 2007 | Logitech (980408) Wireless Headset
Logitech (980408) Wireless Headset Logo
349 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
