I had the same problem when I worked in an office. But when I started my Writing Work From Home Online, it didn't bother me more.
It could be data Cable problem Chang your data cable
SOURCE: Kodak 5300
You have a few options. 1. Use the Printhead cleaning in the Kodak Software this is recomened way and the safest but will use ink each time. 2. Get a T-shirt or another type of cloth that wont leave lint, get some distilled or de-ionized water (tap will work but not as well) and mannually clean the printhead. To do this remove the printhead and look at it. you should only wipe with the nozzels groove. go with the grain not against it. you dont need to put alot of pressure. Place the nozzels on a wet area of the cloth wipe in the directions of the nozzels you can do this on a flat surface or use your fingers to press against. 3. Call kodak say your printhead is dead and you would like a replacement. They should not charge you for it because its not your fault that it does not work.
SOURCE: HP Laserjet 1020 - prints blank documents
in my printer the resistor R348 on the motherboard printer was broken. The value that must have is 10 ohms. I have changed and the printer has resumed work.
SOURCE: toner empty error
myself dev garg from raipur, nakshatra infotech, please change the chip of toner which you may get in rs.100/- aprox. if problem persist then contact me at 9893282285
thanks
toner empty replace toner with without reset chip
i want window file printer start without reset chip run printer
i am all ready use ml1640,ml2245 printer file use
thanks
vijay
SOURCE: I would like to print black with one color cartridge empty
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
