Question about VIA Pedometer - Via Panic
I can't figure out how to turn it on. - VIA Pedometer - Via Panic
I checked this forum this morning because I was having the same trouble. I tried pushing buttons, pushing and holding buttons, pushing buttons together, shaking it, shaking it while holding buttons... nothing worked. Out of frustration more than anything I whacked it on the palm of my hand... and presto! It works. I guess you just need to use the Fonzie method.
Posted on Jan 12, 2010
How do I start the timer on the via pedometer
Posted on Apr 01, 2010
Turning alarms off
I have a I live itp152b and cant figure out how to turn the alarm off
Jul 23, 2013 | iLive Icp122w Iphone r & Ipod r Clock...
I can't figure out how to turn it off and on
press the upper button to turn it on and off.
Mar 20, 2013 | iPhone Apps
How do I change the combination on my Unican 1000 keyless lock? thx john
The door must be open.
On models with the passage feature, make sure the passage feature is disengaged: turn knob or key should be in vertical position (A) (see figure 1).
1. Insert the DF-59 control key (B) into the combination change plug
assembly (
C) and unscrew the cylinder by turning the key
c
ounterclockwise. Remove the combination change plug to gain access to the combination change sleeve (see figure 1).
2. Turn the outside knob/lever once clockwise (all the way, until it stops) then release. The latch should not retract (see figure 4).
3. Enter the existing combination. On new installations, use the factory- set combination: depress 2 and 4 simultaneously, (release), then 3
(r
elease). You should feel a slight click as each button is depressed.
4. Insert the spanner wrench as shown in figure 2 to engage the combina- tion change sleeve (A). Gently turn the spanner wrench clockwise to the stop position (a slight click should be felt), then turn the spanner wrench counter-clockwise to the stop position (A) (see figure 3). Remove the spanner wrench.
5. Turn the outside knob/lever once clockwise all the way until it stops, then release. The latch should not retract (see figure 4).
6. Choose your new combination, write it down, then enter the new combination-depress buttons carefully (a slight click should be felt as each button is depressed).
Note: You can use one button or all five for a combination, but each button can only be used once. You can depress two or more buttons simultaneously as a step in the combination.
7. Turn the outside knob/lever clockwise once, all the way, until it stops, hold in position and make sure the latch is retracted (see figure 5).
R
elease the knob/lever.
Note: If your lock is opening on every turn of the knob or lever, except upon entering a code, this may be a ZERO CODE. Before attempting to remove the lock from the door, refer to the troubleshooting procedures outlined at bottom of this document for a zero code symptom/solution.
1000/L1000 Series FAQ
Changing the Code/Combination
hope this helps
and here is the link to the change code web site
http://www.locksonline.co.uk/files/pdf/Simplex_1000_CodeChange.pdf
good luck
please take the time to rank my advice
merry christmas
Dec 07, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I having a hard time figuring out the headlights
if my memory serves you pull switch toward you to turn on push in to turn off,
Feb 25, 2010 | 1990 Volkswagen Cabriolet
Holiday Express Train Set
We struggled with this just today...finally figured out that you have to twist the small piece right behind the bell on the top of the locomotive.
Dec 18, 2009 | New Bright Small Holiday Express Train
Erased the code
FOR YOUR SECURITY THE
COMBINATION MUST BE CHANGED
WHEN THE LOCK IS INSTALLED.
position (A) (see figure 14-1).
combination change plug assembly (C)
key counterclockwise. Remove the combination
14-1).
2. Turn the outside knob once clockwise
14-4).
installations, use the factory-set combination:
(release), then 3 (release). You should
depressed.
Figure 14-2 to engage the combination
then turn the spanner wrench counterclockwise
14-3). Remove the spanner wrench.
5. Turn the outside knob once clockwise all
latch should not retract (see figure 14-4).
on page 26, then enter the new combination
— depress buttons care-fully
Dec 08, 2008 | Simplex Kaba Ilco Unican 1000 keyless...
Got a new part. don't know how to install it
I assume you either have recieved the separation pad or the paperpick roller. Here are instructions on how to replace both.
  1. Use the power switch to turn the product off and then unplug the power cord. Figure 1: Unplugging the power cord c00062340.gif
  2. Open the print-cartridge door, and remove the print cartridge. CAUTION: To prevent damage, do not expose the print cartridge to light. Cover the print cartridge or place it in a black plastic bag, if necessary. Also, do not touch the black-sponge transfer roller inside the product. Touching the transfer roller can damage the product.
  3. Locate the pickup roller. Figure 2: Removing the print cartridge, and locating roller c00062341.gif
  4. Gently release the small, white tabs on each side of the pickup roller by pushing them away from the roller, and then rotate the pickup roller toward the front. CAUTION: Use gentle pressure to release the small white tabs to avoid breaking them. Figure 3: Releasing the tabs c00062342.gif
  5. Gently pull the pickup roller up and out. Figure 4: Removing pickup roller c00062343.gif
  6. Perform one of the two following options:
    • Cleaning the pickup roller:
      1. Dampen a lint-free cloth with isopropyl alcohol, and scrub the roller.
      2. Using a dry lint free cloth, wipe the pickup roller to remove loosened dirt. Figure 5: Wiping the pickup roller c00062344.gif
    • Removing the new pickup roller from its packaging.
  7. Position the cleaned or replacement pickup roller in the slots on the pickup roller frame. NOTE: Circular and rectangular pegs on each side prevent incorrectly positioning the pickup roller. Figure 6: Positioning pickup roller c00062345.gif
  8. Rotate the top of the pickup roller into position until the white tabs on each side of the roller snap into place. NOTE: Touching the transfer roller can damage the product. Figure 7: Reinstalling the pickup roller c00062346.gif
  9. Reinstall the print cartridge and close the print-cartridge door.
  10. Plug the product in, and then use the power switch to turn on the product. Figure 8: Plugging the power cord in c00062347.gif
  11. Use the power switch to turn the product off and unplug the power cord. Figure 1: Turning off power and remove power cord c00062407.gif
  12. At the back of the product, unscrew the two screws that fasten the separation pad and frame to the product. Figure 2: Unscrewing the separation pad c00062408.gif
  13. Remove the separation pad and frame. Figure 3: Removing the separation pad c00062409.gif
  14. Perform one of the following two options:
    • To clean the separation pad: Dampen a lint-free cloth with isopropyl alcohol, and scrub the separation pad.
    • To replace the separation pad: Remove the new separation pad from its packaging
  15. Insert either the cleaned or replacement separation pad and frame and fasten it to the product with the two screws. Figure 4: Fastening the separation pad c00062410.gif
  16. Plug the product in, and then use the power switch to turn on the product. Figure 5: Turning the product on c00062411.gif
Nov 17, 2008 | HP LaserJet 3015 All-In-One Printer
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
No picture for 3-4 minutes after start up
Roger,
Could be as simple as a software upgrade if the picture looks okay after it come on... What software version are you currently running?
SOFTWARE VERSION CHECK Step (1) Turn the TV ON. Step (2) Using the TV Remote, Select Antenna C. Step (3) Press the MENU button on the Remote. Step (4) Menu will appear
(Figure 1)
Step (5) Press the Cursor Down button and Highlight SETUP
(Figure 2)
Step (6) Press SELECT on the Remote Control. Setup Menu will appear
(Figure 3)
Step (7) Cursor Down and highlight UPGRADES
(Figure 4)
Step (8) Press the SELECT button on Remote Control. Upgrades Menu will appear
(Figure 5)
Step (9) Read the Software Version
Let me know!
Bill
Dec 12, 2007 | Hitachi 53SDX01B 53" Rear Projection...
VIA Pedometer - Via Panic Logo
474 people viewed this question
Top VIA Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a VIA Exercise and Fitnes Expert? Answer questions, earn points and help others
