There is a menu setting called convergence.This allows the customer to align the red,green and blue colors.If the colors do not respond to the adjustments you are trying to make,then you need to replace the convergence IC's and check all associated resistors in that circuit.The resistors could be either burned visibly or open when checked with an ohm meter.If you replace the IC's and have missed a bad resistor,you could burn up the new convergence amp IC's.
