Question about Canon Pixma MP450 All-In-One InkJet Printer
My mp450 won't take paper from the tray. It starts to try to take a page, but only pulls it down from one side and ends up jamming.
    President:
  • 2,306 Answers
You need to look inside with a mirror and flashlight, usually something has fallen in stopping the paper. Yesterday I removed a scrunchie band, last week an ink pen. Sometimes we have to take apart to remove things that don't belong that fall in.
Posted on Jul 28, 2009
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Everytime I send something to print the printer starts normally, it grabs the paper to start printing but then the paper never moves again. It sounds as though the document is actually printing but theres...
I don't know what printer you have, but this applies to all printers. The first paragraph is just for inkjets. The the whole is related to laser printers.
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 15, 2011 | Office Equipment & Supplies
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Jul 10, 2011 | Brother MFC-7440N Laser Printer
My CLX 3175FN printer continues to have a paper jam. Right now I cannot print any paper size without it jamming. What can I do to correct this problem?
Paper jams
85% of paper jams are caused by worn rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Also:
Start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine; quickly open it to stop print and take out the cartridge and look at the drum and the paper underneath. If the issue is there at that point then it would point to the cartridge. If not then it is in the fuser area.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 21, 2011 | Samsung CLX-3175FN Printer
Our machine shows E051. so what can i do.
The JAM DUPLEX message appears if you remove a sheet of paper from the face down output tray after only one side has printed.
The paper sizes you can use with the duplex printing function are A4, Letter or Legal.
If the paper adjustment lever for duplex printing is not set correctly for the paper size, paper jams may occur and the printing will be out of position on the page.
Open the back output tray.
Use both hands to slowly pull the jammed paper out of the fuser unit.
Close the back output tray.
If the paper jam cannot be cleared, go to the next step.
Pull the duplex tray and paper tray out of the printer.
Pull the jammed paper out of the printer
Put the duplex tray and paper tray back in the printer.
Click solved and vote if problem is solved. Otherwise post again
Aug 02, 2010 | Office Equipment & Supplies
Connon ir 1210 copeir paper jam but i can not see that papper size A5
the paper may not have come out the paper tray and this is causing the error check the paper tray settings and the paper side and end guides have the paper held in properly.. if you pull the tray out and press the paper down the guides should be touching the sides and end of the paper this will allow the paper to be fed properly..
Jul 13, 2010 | Office Equipment & Supplies
The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 19, 2009 | HP LaserJet 4 plus Printer
PAPER JAM
Rotate tires. Pull out paper tray. Pull down on red low paper indicator at left bottom. Two rollers come down on axel near center. I pulled off the rubber tire like roller, then twisted the roller inside out and reinstalled it with the fresh side out.
If tires dry out again will probably buy new ones from ebay.
Jun 26, 2008 | Lexmark E232 Laser Printer
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
