Question about Panasonic SC-HT670 System
Jamed the unit says wait the the trays are open except one and it apears to be jamed
  • 1 more comment
  • guygee Dec 05, 2007
    how do i reset the trays
  • guygee Dec 09, 2007
    need to get the draws back in timing can you tell me how
  • paav Mar 05, 2008
    I have the same system and I had broken gears in mine. I obtained a new disc change mechanism (so I know there are no broken gears now) but now I'm having the same problem you describe, with one drawer out and "wait" on the screen.
  • 4 Answers
I've just spent the last 3 nights trying to fix that same issue with my player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Posted on Apr 14, 2008
  • 82 Answers
The changer mechanism needs to be manually reset. Maybe due to a broken gear.
Posted on Dec 05, 2007
  • Riaz Ali
    Riaz Ali Dec 05, 2007
    The mechanism has to be taken apart and examined for any broken parts. Sorry I cannot explain the proceedure for assembling the mechanism.
FS-4020DN "Paper Jam Deplexer"
check for jamed paper above the paper tray in the duplex unit.
=remove tray
=move green lever and open duplex unit
=remove jam
Jun 27, 2014 | Kyocera FS4020DN (A4) Workgroup Mono Laser...
HOW DO I CLEAR FUNCTIONAL PROBLEM SC320 ON RICOH 1018D
It is the polygonal mirror error code.Inspect the polygonal mirror motor,the connection between the motor and BICU unit,the cable and BICU unit.For reset turn the copier main switch OFF disconnect the main cable,wait 1 minute,connect the main cable and turn ON the copier..
Jun 03, 2010 | Ricoh Aficio 450 Copier
Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Apr 20, 2009 | Pioneer BDP-51FD Blu-Ray Player
HAWX open tray
If it says "reading" you just have to wait. H.A.W.X. is a big game.
If it says "open tray" you have to close the tray :)
Unless, Check the CD for scratches and marks, or else try the CD on another Xbox 360 console.
Apr 13, 2009 | Video Game Consoles & Games
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
Need unlock code for Philips DVP5990
Having the same problem!! Please help
Thanks
Jul 26, 2008 | Televison & Video
CD PLAYER.SL-PJ26 Drawer does not open
The tray gears are struck or jamed. need to open the unit.
Jul 15, 2008 | Technics SCEH790 CD Shelf System
Ink System Failure
I just had this problem with a HP C5150 and I found this bit of conversation on the web and it worked for me.
My error code was 0xc18a0501 and the following steps did resolve my issue, hope it helps you as well.
  • OK I had the hp error code 0xc18a0001 problem and here is the conversation I had with the tech.....
    james cowan: hp error code 0xc18a0001
    Earnest: I will assist you in this regard
    james cowan: great
    Earnest: I understand that a error code with 0xc18a0001 with "Ink System failure" is displayed on the front panel of the All-In-One printer. Am I correct?
    james cowan: correct
    Earnest: Thank you for confirmation
    Earnest: May I have the model number of All-In-One you are using?
    james cowan: c6250
    Earnest: Thank you for information.
    Earnest: James, please let me know the room temperature in which printer is replaced
    james cowan: 67 degrees f
    Earnest: Okay
    Earnest: Please perform the below steps on the front panel of the printer to resolve the issue
    james cowan: ok
    Earnest: Press and hold the "left arrow" key.
    Press the "Setup" key and release both keys, Display should say "Enter Special Key Combo"
    Press and release the "OK" button.
    Earnest: Please ignore the above steps, James
    james cowan: ok yes nothing seemed to do anything
    Earnest: Press and Hold the "Print Photos" &"Red Eye Removal" buttons. Release both buttons. Display should say"Enter Special Key Combo"
    Press and release in sequence"Red Eye Removal","Print Photos","Red Eye Removal"
    Earnest: Display should say “Support” and display the FW rev (something like R0616R)
    james cowan: COxxFN0723BR j
    Earnest: Okay
    Earnest: 2. Press and release the right arrow button until the display says “System Configuration Menu
    james cowan: ok
    Earnest: 3. Press and release the "OK" button.
    james cowan: ok and it says hardware failure status
    Earnest: Display should say "Hardware failure status: Clear. Press OK to clear".
    Earnest: Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue".
    Earnest: Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
    james cowan: ok
    Earnest: Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
    Earnest: Let me know once you are done with the above steps
    james cowan: ok its unplugged
    Earnest: Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
    Earnest: Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE".
    james cowan: ok
    Earnest: Let me know the message displaying on the front panel of the printer
    james cowan: printer preparation occuring - do not interrupt
    Earnest: Okay
    james cowan: ok its done
    Earnest: Let us print a self test page from the printer now
    james cowan: ok deal
    Earnest: 1) Load letter, A4, or legal unused plain, white paper into the input tray.
    2) Make sure that the printer is on and loaded with unused plain, white paper.
    3) Press Setup . The Setup menu appears.
    4) Press the down arrow button to select Tools , and then press OK .
    5) Press the down arrow button to select Self-test Report , and press OK .
    james cowan: ok printing
    Earnest: Okay, please check whether all the colors pritned perfectly on the test page
    james cowan: perfect
    Earnest: Great..Cheers!!!
    james cowan: thank you very much
    Earnest: James, now you can continue using the printer
    Earnest: I appreciate your efforts and patience in trying to resolve the issue."
May 26, 2008 | HP Photosmart 3210 Printer
DVD tray will not open
I had the same problem. I opened up the unit and gently released the tray from inside. It has been working fine since - except for the problem I just posted i.e. the remote does not work.
Nov 17, 2007 | Memorex MVD2027 DVD Player
Panasonic SC-HT670 System Logo
449 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
