Question about Mantis 4-Cycle Tiller/Cultivator with Border Edger and Kickstand #7262-00-02
Won't start. have replaced plug and cleaned filter. any suggestions?
    President:
  • 986 Answers
Check and see if your coil is grounded,if not clean flywheel magnet and check for spark if no spark replace coil,
Posted on Jul 29, 2009
2 Suggested Answers
  • 17 Answers
SOURCE: Tecumseh HM80 on coleman generator. won
check to see if it has a smeared or worn key way it is what times the fly wheel to the engine if not it is possible that it coul have problem with a valve or engine timming
Posted on Mar 01, 2009
Yamaha yn 50 got a spark just won't start what
Check there is fuel getting to the spark plug-turn it over and then check the spark plug is wet. Also check the air filter is clean. Remove the filter and see if it will run. If it does then replace the air filter.
Jun 26, 2013 | Motorcycles
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
1 yr old -won't start this year
probably need to clean out carby and fuel tank
Jun 11, 2013 | Toro Power Lawn Mower
Won't start first time, but always starts on the 2nd attempt, any suggestions
replace air filter, clean fuel injectors, and replace fuel filter see what happens.replace spark plugs and wires.
Apr 04, 2013 | 2003 Subaru Outback
Installed new fuel pump and cleaned all 6 fuel injectors but it won't start
Have you checked fuel pressure at the rail with a gauge yet ?
Are you getting spark to the plugs ? Have you tried spraying starting fluid into the intake to make sure it is a fuel problem ?
Dec 15, 2012 | 2006 Toyota 4Runner
2001 Rodeo 2.8 Turbo Diesel running perfectly one day won't run the next. Seems to be after it sits for a couple of days. Any suggestions?
Hi Peter, If the vehicle turns on the starter all the time, and sometimes starts and other times fails, check the fuel filter for leakage. Sometimes air gets into the fuel system. When it gives problems, open the bonnet (hood) and have someone pump the pump on top of the filter housing. If it feels soft when beginning to pump, I would suspect either a leakage on the fuel line or the filter housing. If you need to replace the housing and filter, remember to fill the replacement filter with clean diesel fuel first. the glow plugs can also cause problems if one or more have burned out. Regards John
Oct 31, 2012 | Cars & Trucks
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
I have a PB251 Echo blower that won't start. I have a good spark Good compression and clean new gas is getting to cylinder because i have a wet spark plug when i removed it ,yet it won't even...
I suggest cleaning the carburetor and replacing the diaphrams. The diaphrams come with a rebuild kit that has a lot of unused parts.
Aug 31, 2011 | Echo Garden
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Mantis 4-Cycle Tiller/Cultivator with Border Edger and Kickstand #7262-00-02 Logo
254 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
