Question about Refrigerators
The freezer is working OK but the bottom is not getting cold enough? Is these something bloacking the cold freezer air from going to the bottom.
    Scholar:
  • 86 Answers
If there is anything blocking the cold freezer air going down to the bottom refrigerator is the setting on your freezer control. Try to set the control on the freezer to warmer position. and you may get more cold air going down to the bottom refrigerator. Try that and hope it 'll work for you. If you want to know why, send me a comment and I'll explain to you. Have a nice day, God Bless.
Posted on Jul 29, 2009
Fridge not working but freezer is ok fridge light works
There is probably an ice build up between the two sides of the appliance. There may also be a problem with the damper unit which controls the cold air coming from the freezer side to the fridge. The fridge is controlled by the freezer. Dependant on appliance. The door opens and closes letting the cold air go into the fridge and when the fridge is cold enough the door will close agin. This is not something that you will see happening it is normally concealed behing a diffuser.
Feb 24, 2010 | Freezers
The freezer is working just fine but the refrigerator is not cold at all
CHECK THE FREEZER FAN MAKE SURE ITS RUNNING AND IF THE BACK WALL OF THE FREEZER IS FROSTED UP YOU HAVE A DEFROST PROBLEM. I ONCE FOUND SOMETHING FELL BEHIND THE BASKET SO THE DOOR DIDNT SHUT ALL THE WAY, CHECK THIS AS WELL
Jan 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer not getting cold enough.
That is normal since the cold control is on the refrigerator side and is satisfied. It needs to be in a heated environment and not in an unheated garage.
Jan 02, 2010 | Frigidaire FRT21P5A Top Freezer...
Zanussi integrated fridge freezer, top half fridge not working
It appears you need to get the cold distributed from the freezer section to the frig section. This can only be accomplished by a fan that forces the cold air throught openings between both sections. Since the freezer in at the bottom, cold air cannot go upward, thereforethe fan. Chech that the interior fan (in the freezer section) is running. Check that the air openings between the sections are not blocked. Finally, if all looks good, then maybe the compressor system is slowly failing and only making enough cold for the freezer, but not enough to be circulated. Goodluck, Macgivor
Jan 02, 2010 | Refrigerators
No air flux in the bottom system only on the top (freezer)
Either your freezer control is set to coldest (which basically keeps the freezer cold by shutting off all air flow to the fridge) or your defrost cycle isn't working.  If your evaporator coil in the freezer is frozen over, melt the ice and replaced the defrost heater and thermostat.
Dec 04, 2009 | Refrigerators
Whirlpool ET20GK top freezer works ok bottom refrigerator does not cool. I defrosted, the two air passages from top to bottom are open. The fan in the freezer is running .Is there another fan? I vacuumed...
make sure you air damper in the refer section is open
and allowing cold air from the freezer in to refer section, close the freezer door and make sure you can feel the cold air dumping in
its good thaty you cleared the two air passages
but something may be clogging your air diffuser
Oct 26, 2009 | Refrigerators
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Cool compartment is not cold enough
Hi, Have you noticed an ice or frost build up at all in the freezer section. Is the freezer holding a zero to 5 above temp?
I will try to help you though this. please let me know.
Thanks
Vic
May 13, 2009 | Refrigerators
Fridge not cold enough, Freezer ok
The refrigerator gets its cold air from the freezer section through ducts and damper control. Check for blockage.
Apr 27, 2009 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
