Question about Whirlpool GBD307PRS Stainless Steel Electric Double Oven
Had a power failure and now getting a PF E1 error on the control panel
We recently had a power failure and now I'm getting a PF E1 error on the control panel. I have tried to cancel everything, cut the power and tried to reset it. The bottom oven is locked and I can't figure out how to get that off. Every once and awhile I hear a ticking coming from the bottom oven. Can someone please help, can't find any data on whats wrong or how to fix. Any help would be greatly appreciated.
  • uncw00 Nov 22, 2007
    Sorry on the previous post, the error is a F5 E1
I am having a problem with a Whirlpool Stove. The Error Message on the Control Panel is PF.. I tried clearing this PF signal and it does not work. What should I do. I hear a ticking from the control panel when I press the Off bottom to clear the PF signal.
Where should I do. Where are the fuses located on the MODEL NUMBER Whirpool Model GJ8490 .in Canada
Posted on Dec 23, 2007
  • 473 Answers
F5 - E1 and E2 Check door/latch switch Replace switch if defective
It has detected a problem with the switch on the door lock motor. In most cases the switch will need to be replaced.
Posted on Nov 23, 2007
Power Failure while oven was in self cleaning mode. When power was restored the control panel is completely dark, no error codes or PF indicator. The oven door is also locked after 24 hours, so the the...
Hello. You have an open rear oven thermostat causing the complete power failure of your unit. The part numbers you need are W10176670 for the upgraded blower and 9759243 for the thermostat. You will have to remove the oven from the wall in order to remove the back covers to access the thermostat and blower. The blower has been upgraded from 950cfm of airflow to 1200cfm. I have performed this service flash--you will definitely need a helper or 2 in order to pull the oven out and work on it. There is a service bulletin on your oven describing this exact situation. When you replace the thermostat and blower, re-mount the oven and then restore power, the oven will function and unlock. The link for the thermostat is here:
Thermal Overload Safety Thermostat
The link for the blower is here:
If you are hesitant about performing the repair yourself, definitely call for service. I hope this helps you!
Nov 06, 2015 | Whirlpool RBS305PRS Stainless Steel Oven
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
How to get a pf code off . Just installed new control panel and this code is all that shows up. Help it a frigidaire oven mod. Ples389ech
I appreciate your inquiry, J.J!
From what you have described your Frigidaire oven is displaying an error code of "PF" and you just installed the control panel. A "PF" error code stands for power failure. This could be a possible problem with your control panel and power source. You may need to perform a reset on your oven and you can do that by flipping the household circuit breaker off for at least ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to you. -Matt
May 10, 2015 | Frigidaire Ovens
What does the message PF mean?
PF = Power Fail. Possibly damaged control board.
Dec 23, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
Power failure control panel beeps no lights on panel and oven wont turn on. have lights on inside of oven. do i need a code, never have before. always showed PF for power failure.
Was the oven doing a self clean when the PF occurred? If so the cavity limit probably tripped.
Sometimes the owner wants to shut down the process of self clean for whatever reason that also trips the cavity limit. If the oven circuit breaker is weak then their could be a power failure during which the oven was on and that could cause the cavity limit to trip. No lights on panel means the temp inside the oven control panel exceeded normal operating temp and the small inline fuse going into the control panel has melted:
This is what that small fuse looks like. To get to the insides
you usually drop the side trim exposing the screws then the controls fold outward.
Service manual for American stoves and more
Oct 23, 2011 | Whirlpool Ovens
Replaced control panel on whirlpool electric double wall oven. e1 f5 code pops up,fault code says check door latch. checked switches on latch with meter check ok.what to check next
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$RED
Feb 28, 2010 | Whirlpool RBD275PD Electric Double Oven
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My oven is giving me an error of E6 F2, what does that mean
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control board. Problem initially presented on display as error & fault "E6 F2"; simply pressing "Timer Off" would usually clear this error & fault code.
However, some months later, the display would often go completely blank followed by the beep sequence "short-long-short-short-short" (Morse code: dit dah dit dit dit). No error & fault code would appear. Pressing any keypad oven control did not work at all in this condition. When power was cycled at the breaker panel, the usual "PF" with clock display did not appear.
After following the excellent information on "how to remove the control panel" posted in this forum, I first tested the "control panel thermal fuse" (refer to the tech sheet that should be behind the control panel once it is removed). It showed a closed circuit.
I turned my attention to the "flexible" keypad connector cable (error & fault code "E6 F2" is a keypad or keypad connector problem; again, refer to tech sheet). The control panel has a board mounted female connector with two tabs that may be gently pulled upward to release the flexible cable.
I cleaned the flexible cable contact area (it seats into the board mounted female connector) carefully with a Q tip and some isopropyl alcohol. I reinserted the flexible cable and gently pressed down on the two tabs (noted above) on the board mounted female connector. VERY GENTLY tug on the flexible cable to insure it is gripped by the connector.
After all of this monkey business, I re-mounted the control panel display panel on the oven and restored power. So far, so good. After applying power, the "PF" with clock display always appears. I am able to set the clock and press "Start". Over functions normally. The clock displays as normal and I no longer observe the problem I described above.
BTW, I noted the incoming 240V has transient suppression (no surge protection, however
Sep 19, 2009 | Whirlpool Ovens
Indicator light says ''pf''
Jun 24, 2009 | Ovens
Whirlpool GBD307PRS Stainless Steel Electric Double Oven Logo
661 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
