Question about Water Heaters
Cant find how to change temp setting
Rheem 30 gallon electric water heater...model 615v50c...cant find how to turn the temp up or down. can u help?
  • 2,418 Answers
You have a panel down at the botom squease it together and it will come out (tabs in a slot) in this access area is your controls, Your t-stat just looks like a small box with a pointer on it, you will need a small screw driver and turn it to the temp you want. Move it a little at a time. Not to hot it can cause the pop off valve to pop if it is old.
Posted on Jul 28, 2009
Turned down temp on Water Heater a little, and now we are not getting any hot water. Not even Warm. Whats wrong?
For electric tank: Push in the reset button located on upper thermostat.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
For gas tank, then more specific information might be needed for example if unit has power vent, when was the air intake cleaned, is the pilot lit, what brand and model number etc etc..
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
For tankless, or solar, or hybrid electric, gas boiler, or indirect, or RV heater, etc then please include brand, and model that appears on label on side of unit.
Sep 05, 2012 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem electric water heater 50 gallon, lukewarm water. Water is warm but not hot, where should we look for problem?
Luke warm water is the result of top element bad and the bottom is the only one heater. The best solution I can reccomend is to change both out due to the fact the bottom element may go bad and since you have to change one you might as well change both.
Turn power and water off, drain heater down and once water is drained out change them out. Once new ones installed turn water on to fill heater and open faucets and get air out on the hot side of each faucet once water is flowing out of each faucet you are now ready to turn power back on.
Oct 12, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
How do you set tempature to make the water stay hotter longer? I have a Rheem 82v66 2 (65 gal) and cant fill my bath tub with out running out of hot water.
65 gallon water heater should fill more than 1 bathtub since typical bath only uses 12-14 gallons hot water. First hour delivery on your tank should be greater than 60 gallons.
http://waterheatertimer.org/Hot-water-use-chart.html
Since you have such a small amount of hot water, it sounds like bottom element is burned out, or one of the thermostats is bad. There are two thermostats, and two 4500 Watt elements on 65 gallon tank.
If upper element was burned out, or water heater was not getting 240V electricity, then you would have NO hot water. So we know upper element is good and circuit is good.
Ordinary tank-type electric water heater is fully repairable by homeowner and parts are available at hardware or home center.
I suggest taking 30 minutes and doing troubleshoot before replacing any parts.
Buy cheap multimeter from home center.
When testing voltage, rotate multimeter dial to 240-250-277 VAC
When testing elements or continuity, rotate dial to Ohms.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help. I can answer questions as you fix the water heater.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on heater.
Jan 11, 2011 | Rheem 65 GAL ELEC Water Heater 6YR Self...
New Rheem electric 50 gallon not heating
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Jun 01, 2010 | Water Heaters
Water heater not firing up
Make sure thermostat is turned to 120 to 150 degrees Fahrenheit. Turn the thermostat down and back up to see if it ignites. If it lights put the cover back on and set it to temp you want it to be. if not, you have a bad thermostat.
Hope this helps.
Aug 14, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
37 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
