Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Exact problem I also have a sony bravia 1080p that is only 10 months old. It now has thin flickering vertical lines all over it. Almost forming larger bars. They seem to interact with the screen images. Such as shadows on peoples faces will have lines but the cheek area wont. I've tried new HDMI cables and reconnecting everything. Nothing works so far. Luckly I did purchase the 3 year warranty. I will call them if no one can help. It seems like there must be a simple solution since it is still new. Maybe it is a lemon though.
  • mlbass Jul 28, 2009
    Model KDL-40s4100 and it has never been damaged or hit at all.
  • mlbass Sep 06, 2009
    Well I called in the warranty. It took 29 days to fix. First they thought it was the panel, not the problem. Turns out it was the main circuit board. It now works like new again!! Finally! Thanks for the help and support. :D
    Scholar:
  • 73 Answers
This is an internal malfunction, deffinately use the warranty on it. If you decide to fix it yourself post again and I'll walk you through changing the LCD controller. Its not too challenging, but will require you to dismantle almost the entire tv.
Posted on Aug 11, 2009
I have a vertical line in the middle of my screen
Call for warenty repair,ur tuner board have problems.Or tries bring it back at were the store u buy it at.Return it exchange for another one.
Mar 23, 2010 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My 52inch xbr4 tv is 2 years old. Intermitently over past 2 months, when I first turned it on, I get thin vertical lines and double imaging especially over left half of screen. After a few minutes it would...
I have the same issue. Bought the TV 1/08 and it started showing those exact symptoms about 3-4 months ago. It generally progresses and gets worse. You can try to fix it as it's some kind of TAB connector issue, or keep calling Sony so that the 52" owners of the XBR4 and 5 series get the extended warranty just like the 46" owners received for the same series. If enough of us keep calling, they'll have to act.
Jan 18, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Less than 24 months old. Power up, has 3
sorry to say but your LCD panel is failing, and will have to be replaced sonys panels are expensive
Dec 05, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Thin vertical line
You are going to find it is a LCD panel problem. I am sure that they will take care of you. But also realize that this could have happen to any brand of LCD panel and you will probably not have any other panel issues once it is fixed.
I feel your pain,
Skyassoc
Jun 21, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia 46Z4100 has a thin vertical red line on the screen
I assume that when you get the line you lose the picture, if so, you have vertical collapse, either a dry joint in the vertical section or capacitors or vertical I.C., I would doubt that the scan coil would be O/C as that is rare. if you can't do it yourself I suggest taking it to a repairer, as it should be an easy fix...Hope that helps...Phil
May 19, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
480 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
