Paykel and fisher washer keeps repeating cycle
  • tony1per Jul 28, 2009
    The washer completes the entire cycle, then starts the washer cycle all over again.
    My washer completes the entire wash cycle. At the end it starts all over again.
  • 15,935 Answers
The timer is defective.
You will need to replace it.
Thanks:D
Posted on Jul 28, 2009
  • 3,037 Answers
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
* It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
* It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Also, if the drain hose is stuffed far down the stand pipe, the timer will get stuck. You can order replacement parts from www.repairclinic.com and if replacing a part doesn't help, you can return it within 30 days. Let me know how this turns out.
Benjamin
  • Benjamin Patri
    Benjamin Patri Jul 28, 2009
    Do you mean that it just does the wash cycle, or does it then go to the rinse and spin cycle
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
Aquasmart wl80t65dw1
Hello Tim. This is an annoying issue with the FP washers from the GWL15 and up. You will need to replace the main control, p/n 421232NAP If the unit is under warranty, call Fisher Paykel for service. If not, the control costs $168.00 US and is a fairly simple proceedure to replace.
Apr 09, 2014 | Fisher and Paykel Washing Machines
F&P Washing Machine. WL80T65DW1. Washing cycle doesn't end...
Hello Tim, This is a frustrating issue on the F/P washer. You will need to replace the control board in order to solve this problem.
Does it matter which wires goes where on a diverter valve for a Fisher Paykel GWL15 washer?
I thought they could only plug in one way? if not, it shouldn't matter, just keep an eye on it first cycle. it activates the diverter right near the start of a cycle.
Oct 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
**** buildup in top load washer. what to do
Unscrew the agitator and wipe out all accumulated muck. Screw agitator back on, and put through a rinse cycle with white vinegar and bicarbonate soda. This will flush any residual scum. You may have to repeat procedure every 6 months.
Dec 03, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel washer keeps saying cutoff restart
The power supply is faulty in the motor controller.
Replace motor controller with new/Reconditioned board.
Apr 25, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
Fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
