Question about Jenn-Air JFC2089HE French Door Refrigerator
I want to replace the water filter - what size/type is acceptable on jfc2089hes?
  • 77 Answers
Look at old filter and get # off filter and take it to local hard ware store and they will give excat filter or they will have a replacement # Make sure to measure inlet and outlet sizes to in sure proper filter instalation..
Posted on Jul 28, 2009
Water to ice maker ok. but no water will come out dispenser
It sounds like the dual water inlet valve has failed for the water dispenser side. New one will cost $50-$60 online. If you feel comfortable check the voltage back to solenoid by depressing water dispenser switch to rule out the switch.
Feb 19, 2013 | Jenn-Air Refrigerators
Jenn-air JFC2089HES french door
Check the water hose and make sure is not kinked.
The hose might be frozen as well.
Mar 31, 2008 | Jenn-Air JCD2295HES Side by Side...
What factors should I be taking into consideration when buying a portable water filter?
You should think about the following aspects - pore size, type of chemical treatment, life span of the filter (on average), the amount of time it takes to filter on liter/one gallon of water, ease of finding replacement parts and price.
Aug 26, 2012 | Brita Camping, Backpacking & Hiking
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
Icemaker has always been slow. It produces ice, just a couple or 3 times a day. We have to keep our old fridge running just to get enough ice... Cubes are full size, freezer is 0 degrees, not much...
The main reason behind an icemaker to make ice slow is the freezer temperature. It needs to be below 10 degrees. Also check the water inlet valve. Water is controlled by a timer and if its obstructed or slow filling, it will not make ice. You could also have a bad motor, defrost heater, or sensor. If these items fail, it usually won't make any ice. Check to be sure the electric plug from the ice maker is plugged in and check the water flow. However if it is filling up with water or if it just has a small amount in the cube maker. If it's making some ice, it's probably not a defrost problem. Check the voltage to the fill valve. Also replace the freezer's water filter, as clogged filters block water flow. Set the ice maker arm to "Off," and then twist the hanging filter cup counterclockwise to remove it. Rinse the cup under running water and discard the old filter cartridge inside. Slide a new filter cartridge into the cup and reinstall the cup assembly in the freezer.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 27, 2011 | Kitchen Ranges
It is an Aprilair Humidifier 220 with thermostat control. The unit is attached to the furnace and for 3 days, we have had water on the floor! We just moved in 2 months ago and are not familiar with a...
Check the drain on the humidifier (at the bottom there is a drain which should be attached to some type of hose that drains into your sump or other wastewater orifice)...
check the filter (remove the lid and the filter is that corrugated metal type thing (it may be clogged causing overflow - you can replace it for about 7bucks at home depot)
also check that the water line (should be attached to the black plastic frame is attached and the water is going into the top part of the black filter holder)
check that the filter is sandwiched properly within the black plastic holder
lastly check the actual holes in the black plastic filter holder to make sure they are not clogged
remember to bring the old filter to confirm size for the replacement
Jan 28, 2011 | Heating & Cooling
I purchased a new kenmore in 2009, and the delivery co. did not provide me with any manuals. I replaced an old Kenmore of exactly the same type, except this one has a WATER PURIFIER. No where do I find the...
www.managemylife.com/mmh/owner_manuals/5365/KENMORE-Side-by-Side-Refrigerator-L0804114
The instructions for changing the water filter begin at the bottom of page 12.
Dec 29, 2010 | Kenmore 53642 / 53644 Side by Side...
The canister that holds the water filter in my whirlpool refrig. is leaking .model# ed5fhgxkq03 . the 2 tubes coming from the back may be the problem .can they be replaced.
Check the filter itself , around the end inserted into the housing , to see if it is cracked . I recently install a new housing , due to water leak , and turned out to be the filter itself which was cracked . But , yes , the 2 lines can be purchased from any hardware store ( this type of tubing ) . Just cut a small piece and take with you , so you can get the correct size (s) . Doesn't have to be strictly refrigerator tubing .
Sep 19, 2009 | Refrigerators
Water dispenser worked perfectly for 9 months. Today, no water comes out at all.
hi michael! you may have to get out your owner manual and read about how to change the water filter. get back if u need assistance
May 09, 2009 | Refrigerators
Size filter
The C-8080 will accept standard 58mm filters.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Jenn-Air JFC2089HE French Door Refrigerator Logo
190 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
