Question about Car Audio & Video
I have a Ford stereo on a car which is 8 years old. Whilst using the car radio last week,the reception for the station went off. I tried another preset station; that was also off. I used the search to find another or any station and nothing would work on FM or AM. The CD player works fine, but I have not been able to listen to the radio since. The aerial is attached and the clock on the radio is working via the RDS signal.
  • 2,200 Answers
Hi
If you are sure that the aerial is attached and there is no break anywhere in the antenna connection then you should know that there is a common fault with tuners on these units.
The Ford 6000 unit in particular (and you don't say if this is your model or not) is extremely prone to this. What happens is that the tuner module in the unit itself fails causing intermittent or permanent loss of reception. This happens to practically all of these units at anytime after around 6 years or so.
The tuner units can be repaired for around $60 but the unit will have to go for service repair as it involves unsoldering the module from the circuit board and replacing it with a new one.
One method fully diagnose this as a tuner issue and to absolutely ensure there is not a problem with the antenna on the car itself is to purchase a cheap antenna - remove the unit from the dash and plug the cheap antenna into the back. You do not need to attach the antenna to the car body for this purpose as it is purely for testing puposes. If there continues to be no radio reception then the problem clearly lies within the tuner module in the radio itself.
Hope this helps and remember to rate my answer. Many Thanks
Posted on Jul 28, 2009
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
I have a Sportster 5 radio and I get in and out radio reception which started the last couple of weeks, have changed the antenna and docking station but still have the problem? Can it be the receiver...
Yes. In fact, it probably is. At TSS Radio, we have seen a lot of SP5's with an antenna connection issue. This is a problem our repair guy is able to fix.
Jun 16, 2011 | Audio Players & Recorders
Merc C200 - Problem with aerial?
try takeing back out and see if the conection on the back has come off if not have a look at the conection its self
Mar 29, 2010 | 2000 Mercedes-Benz C-Class
Dual xhd6425 Reception Problems
My XHD6425 seems to be very inconsistent... Sometimes I get okay reception, other times I get terrible reception (much worse than my original stock Ford radio). The reception problems are more noticeable on stations that are more than 30 miles away or so.
Perhaps oddest of all, I've sometimes had it bounce back and forth between two stations (like if you are driving and in the middle of nowhere, half way between two stations), even in areas where I know should be getting good reception on one station and had never heard of the other other station before.
If you've figured anything out, please let me know.
Jan 16, 2010 | Dual Electronics XHD6425 Car CD/ MP3...
Bad reception
Try to swicth your settings to local,so you can pick up your local stations.
May 16, 2009 | Car Audio & Video
AM/FM stereo receiver often fully "drops" the reception of listened to radio station(s), or reception will often decrease in volume. Repositioning of the receiver's connected antenna wire often has no...
Possible solution. I have fixed two with this problem. When the radio drops to a hard surface, the ferrite coil antenna is the heaviest component on circuit board. Look for cracks in solder or broken wires where attachments to circuit board occurs for this component. Use a fine point soldering iron with low heat.
Oct 12, 2008 | Audio Players & Recorders
SL100 static and bad FM reception
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
Apr 08, 2008 | Sirius STILETTO 100 MP3 Player
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
