Our power went out last night and I cannot get the tv set back to channel 73 which is the channel set for our DISH network. It only goes to 69 then starts over at Vid 1 and Vid 2.
    Genius:
  • 1,043 Answers
Channel # 73 may have been deprogrammed from your TV's memory. Follow the instructions in your manual to add the channel back in.
Posted on Jul 28, 2009
I'm tring to change my sylvania tv 6424tfs to channel 73 it's not letting me
It sounds like the main system control memory IC to your set is faulty. Even though, this IC is very small in size, and very cheap to buy, the function to it, when the TV is switched on is great. It will be best to contact any service technician in this case. To get some details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 10, 2013 | Sylvania 6424TFS 24" TV
Why can't I get tv to channel 73 for dish hookup
The set returned when power removed to the AIR band which only goes up to 69.
Go into customer menu and change from AIR or ANTENNA to Cable or CATV.
Jun 17, 2012 | Televison & Video
Hi, my Phillips was hooked up and working fine directly to the DISH receiver using the HDMI 1. I moved and had to put the DISH receiver in another room and ran a coax cable to where the TV is now using...
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at thomas.faust@dishnetwork.com if the problem persists.
Tommy Faust
DISH Network
Mar 09, 2011 | Philips 42PFL5332D 42 in. LCD Television
I bought a new TV for my #2, but is says I'm not getting a signal when I hook it up to the cable. I have it on channel 60
djpeter770
You can go to TV 1 to make sure TV 2 is suppose to be set to channel 60. Did you run the auto setup on your TV? If you have already run the auto setup on your TV, unplug the receiver from the electrical outlet for 10 seconds and then plug it back in. This will make the receiver reboot and re-acquire satellite signal. Then see if you get a picture on your TV 2. If not, the last thing you can try is changing the channel from 60 to 73 through the receiver.
With your DISH remote at TV 1, press the Menu button - Main Menu will display on the TV 1. Then press 6 (System Setup), 1 (Installation), and 5 (Modulator Setup). On the Modulator Setup screen, move over to TV 2 Out and select Cable, then press select on the remote. This will automatically change the channel from 60 to 73. Highlight Done on the right and press select. Cancel out of each screen till you get back to the TV screen. Go to TV 2 and put the TV on channel 73. You should get a picture. I hope this helps.
Ray Calo
DISH Network
Feb 16, 2011 | DISH Network ViP622 DVR DTV Receiver /...
Need to change channel to 73 so my dish tv will work, it seems the highest channel tv set will go is 69
We would be happy to help with that. Some TV's do not havethe ability to go as high as channel 73; this may be the case for your (enterbrand here). We would recommend changing the channel that your DISH Networkreceiver outputs the picture for your TV2. Start by pressing the"Menu" button, from the main menu press 6 for "SystemSetup", then 1 for "Installation", and then 5 for"Modulator Setup". Under TV2 we are going to change the mode to"Air", the channel displayed beside it should change to 60, selectdone on the right side of the screen to save the changes. Now change thechannel of your TV2 to 60 and you should get the DISH Network programming. Wehope this helps. Thanks so much for being a valued DISH Network customer! Phillip Chang DISH Network Customer Service Representative
Nov 30, 2010 | RCA 27F530T 27" TV
Can't get signal on tv2
Hello! Daniel Busa with Dish Network customer service. The first thing I would do is try unplugging the reciever for ten seconds, then plugging it back in. If that doesnt do the trick, make sure the tv is on ch 60 or 73. If it goes to 73 and there is no picture, go to tv1 hit menu 6-1-5 under tv2 out it will say 60 or 73, you'll want it set to 73 highlight cable and hit select. If the tv doesn't go above 69 make sure tv2 is set to air 60 don't change tv1's setting during any of this.
Nov 26, 2010 | DISH Network 322 DTV Receiver
I have a Samsung 27" TV and need to set it on channel 73 to get a picture from my Satelite Dish. The highest channel the tv goes to is 69.
Set the TV to cable tuning mode and use that channel 73. You have it set for air now so it can only tune to channel 69.
Apr 26, 2009 | Samsung TXN2771HF 27" TV
Settting tv to a higher channel for cable`
Most TVs have a choice of air or cable in the menu portion of the tv. press menu go to setup and from there you should see an option that says air/antenna or cable. You will have to either toggle to get the air selection or highlight it. Then you should be able to get to channels you need.
An easier solution may be to go to the Dish receiver that controls the image on the tv you can't get to 73. With tv and satellite on (make sure both green and blue lights are on) press on your Dish remote #1 with the green tab on the bottom the following sequence: MENU - 6-1-5. tHIS WILL TAKE YOU TO THE MODULATOR SET UP PAGE. Move the highlight from cancel to the mode section an highlight AIR and press select. Then move the highlight back to the right to DONE and press select. Press cancel three times or view live tv. then go to the other tv and put it on ch 60.
Hope this assists you.
Sep 09, 2008 | Symphonic ST420FF 20" TV
Does tv go higher than channel 69
In 1998, UHF-69 was highest channel. you need that TV which has today's technology.
May 29, 2008 | GE Televison & Video
Satellite dish network codes/innovage jumbo remote controll
Dish Network (0101)
Key 1: 02 5A 2E 09 C9 B6 CD 1C A6 FA AF 34 8D 2B CE 79
Key 2: 4F C1 6C 53 93 15 D3 11 B0 E9 F5 15 35 52 86 04
Dish Network (0106)
Key 1: 04 AD BD 42 87 73 73 64 1F 4A 1F 41 55 4C 4B 69
Key 2: FF 14 A5 BE DA 7B D9 99 73 E3 06 85 34 69 22 45
May 02, 2008 | Televison & Video
150 people viewed this question
 Grubhead
Grubhead
